Wow - shockingly hot
1902 6 2017-8-9
StarFishUK
Flight distance : 54970 ft
I decided to copy the video files from the Spark to my PC. There was quite a back log of video clips on the Spark so I thought I would copy them all off to free up space. I connected the Spark via the USB port and powered it on with a battery as normal and left it copying - it took several minutes. When it finished I watched a few of the clips before deciding to power down the Spark and put the battery on charge.
When I picked the Spark up it was so hot I almost dropped it. I powered it down quickly and took the battery out (which wasn't really hot at all) and about 20 minutes later is seems to have cooled down. But I was amazed how hot the top of the Spark had got - not through flying, but just through being powered on and connected to a PC. It also had that hot electronics and plastic smell. I don't think it's taken any damage - it all seems ok - but I wondered if this was normal. It gave me a bit of a fright.
I can't share any log files, becasue this wasn't in flight. It was just sat on my desk, in chilly Scotland, connected to my PC.
2017-8-9
HTWEELZ
Flight distance : 141549 ft
I've noticed that mine gets hot just sitting inside running when I'm upgrading the firmware it just checking things out. I'm sure part of the cooling is it actually flying helping get the air through the Spark. So if that airflow isn't there I'm sure it would get hotter than normal flight. Mine does get warm just flying also.
I usually remove the card and put it in my computer to transfer files.
2017-8-9
STech - Hathder
Flight distance : 459094 ft
Brazil
I live on northeast of Brazil, its a very very hot place, usually 37-40c. My spark never gets hot to touch even after flying on mid-day sun  , the airflow of cooler is always strong (i can feel the flow). I think some cases of Sparks falling of sky are malfunction of cooler.
2017-8-9
Monochrome
Flight distance : 12710 ft
Poland
It's  normal. Spark always gets very hot when it is not flying. It would shut down if it got too hot.
2017-8-9
StarFishUK
Monochrome Posted at 2017-8-9 07:45
That's good to hear. Thanks everyone for your comments.
2017-8-9
Lian82
Flight distance : 796775 ft
StarFishUK Posted at 2017-8-9 07:46
n flight, only the rotors and the battery (because they are discharged) are hot
The spark is never hot. Or at best tepid.
2017-8-9
DJI Thor
Flight distance : 13602 ft
It is normal that when the drone is powering on the battery gets warm. You can connect it with the app and check the battery info when the battery cooling down. BTW, the flight data will generate a flight data once you power the drone on.
2017-8-10
