Does the Spark need to be turned on to get files off of it?
1384 8 2017-8-11
GEddy2
When the spark is hooked up to the computer does it have to be turned on the whole time to grab the files off of it?
2017-8-11
Mimus
Flight distance : 284770 ft
yes, However you can just remove the memory card and if you have a card reader go that way.
2017-8-11
Aeromirage
Flight distance : 1778045 ft
I just pull the Micro SD and load direct to computer.
That way I can review my shots and then delete / wipe the card without using batteries.
2017-8-11
Virgil Quick
Flight distance : 1074104 ft
I have been using DSLR's for many years and have found that for maximum dependability it is advisable to format your memory card often.
2017-8-11
DJI Susan
I would recommend you to turn on the aircraft when connect it with PC.
2017-8-11
GEddy2
The sd doesn't work in my computer so the only way is to turn on the drone and connect it to my mac
2017-8-12
S-e-ven
Flight distance : 5922034 ft
Thailand
GEddy2 Posted at 2017-8-12 16:01
You could use a 32GB instead of a 64GB SD
2017-8-12
GEddy2
S-e-ven Posted at 2017-8-12 18:14
It's not the size of the sd card, for some reason it won't allow me to upload the files through the sd itself
2017-8-12
S-e-ven
Thailand
I only thought about the "max 32 GB if use on mac" hint from the Spark-Manual.
Could have been a quick solution.
It isn't , sorry!
2017-8-13
