A CW
Flight distance : 13864580 ft
'Follow Me' tethers the GPS in the cellular device. 'Active Track' (totally different intelligent flight mode) traces and follows the subject using the main sensor in the camera. Therefore follow me will not work without a GPS module in the device and active track will work depending on sufficient lighting conditions and a clear line between the main camera and the subject at all times or the track will be lost. In addition, you will not be able to use the dynamic home point feature in the app to reset your home point to either the drones current position or your new position mid flight if your device does not have GPS too. It is my understanding that GPS is only inclusive with cellular devices so if using a WiFi only device you can not use follow me, cache maps in real time whilst flying, upload live feed to social media or use the dynamic home point. Everything else works fine. GPS in the drone is not to be confused with GPS in your device. Whilst not essential it is advisable to use a cellular device in order to be able to fully utilise all of the features of the drone. |
