ImHereToCrash
Flight distance : 5381368 ft
i dont dispose of lithium batteries.. if they are "broken" or running weak, i tend to manually charge them bypassing the smart circuits and i have had fairly good success on reviving dead lithium batteries from drills and other high current applications... fairly easy if you have a bench power supply that's capable of constant current and constant voltage. first safely desolder the terminals off cells, noting the polarity, set it to 4.200 V charging and set current to .500 mA it take a while to charge up if flat, make sure bench supply switches over to constant voltage mode once reaches 4.1/4.2V. once charged run a discharge curve test.. set the discharge to 1 amp and set cut off at 2.8V note the time it took to go from full to flat and using 1 amp curve makes math easier new battery has 3,830mAh.. means 1 amp discharge rate it should run you 3.8hours with new battery.. .. start charging again.. same settings. half amp.. 4.2V .. figure the math hour actual capacity.. a lot of times lithium cells are in fantastic condition and can hold 80% or more charge at end of 12 months of heavy use, it's the circuitry that isn't calibrated or is the problem.. if you do have a lot of capacity left then i suggest not tossing it and retrying the intelligent board the mavi barriers include. a lot of time if the board isn't damaged and the board is just out of calibration, it will work again.. if board fails again, then harvest the cells for another project maybe... |
