Goggles wont turn on (DJI Thor)
12Next >
7414 66 2017-8-12
DennisMurry08
Flight distance : 5948264 ft
I finally was able to video the issue I have with my goggles. Got any ideas? Sometimes they work, sometimes they dont.
2017-8-12
DJI Thor
Flight distance : 13602 ft
Thanks for the feedback, I'll confirm this with our engineers and reply you once I heard from them.
2017-8-13
DJI Thor
Hi Dennis, we suggest sending this Goggles in, please fill in some info on our online repair link of our official web and then send it back. Here is the link: https://repair.dji.com/en/SelfRepair/Area
We will do our best to help this out. Thank you.
2017-8-13
DennisMurry08
DJI Thor Posted at 2017-8-13 18:25
Ok.... thanks
2017-8-14
DennisMurry08
one other thing...how do I get the goggle icon below the avatar? I see others have it...
2017-8-14
DJI Thor
DennisMurry08 Posted at 2017-8-14 10:30
If you activate the Goggles with the same DJI account as the forum's, try to sync your flight record, and it might take one to two weeks to show this avatar. You can sync by this route: launch DJI GO app----upper right icon for DJI GO 4 / upper left icon for DJI GO ---- flight record----upper right cloud icon---- select all and start synchronization.
2017-8-14
DJI Thor
Thanks for the kind understanding. Hope we get it sorted quickly.
2017-8-14
DennisMurry08
DJI Thor Posted at 2017-8-14 23:46
Yes...I've done that a few times...the distance is over 200,000 under what my flight records show too...
2017-8-15
DJI Thor
DennisMurry08 Posted at 2017-8-15 08:13
Please try to sign out and log in the forum again. If it still not shows after 2 weeks, please reply me this case and I'll help to check.
2017-8-17
DennisMurry08
DJI Thor Posted at 2017-8-17 00:16
dennismurry08@comcast.net   Yes I have flown several times with the goggles..thanks
2017-9-5
DennisMurry08
Thor...seems this problem is related to the connection between the headband and goggles. When it doesn't work I push tight on the connection and it works...I ve also tried disconnecting and reconnecting the headband...sometimes that works..I've cleaned the connections and done all the standard DIY fixing but will ultimately send back...it's just right now is prime time for filming and I've got spoiled with them.
2017-9-6
DJI Thor
DennisMurry08 Posted at 2017-9-6 20:31
For the avatar of the Goggles, I had forward to someone to look into, will reply you once I heard from them. And for the Goggles itself, our engineers decided to advise you to send it back when it is convenient. We will do our best to help it out. Thank you for your patience.
2017-9-7
DJI Thor
Hi there, I got news from the related team about your icon of Goggles. We had checked your account and found that Goggles is not at the activation machine list under your account. It might be that the Goggles is not activated successfully. Have you received your Goggles now? Please provide your Goggles' serial number so I can check.
2017-9-21
DennisMurry08
DJI Thor Posted at 2017-9-21 20:19
ODLDE660010943 Yes, Ive been using them..I first activated through Go4 ...I just tried to do it again through Assistant 2 but it recognizes my account and doesn't give me an option to activate.....
2017-9-23
DRONE-flies-YOU
Flight distance : 1450594 ft
DennisMurry08 Posted at 2017-9-23 16:55
When you get these sorted, don't forget to try those focus-fixers.com things. Those made my goggles extremely sharp & of course more immersive. They also helped to nearly eliminate ALL of the light bleed from the temples of your head area.
Hope this helps.
2017-9-24
DennisMurry08
DRONE-flies-YOU Posted at 2017-9-24 10:37
Hope this helps.
Yes I plan to...I see everyone is happy with them...I'm trying to figure out the ones I need...looks like I need maybe a different one for each eye which they said they can do..but they got impacted by the hurricane and can't ship till late October....
2017-9-24
Celsus
Flight distance : 196594 ft
The single press appears to show a single led which indicates the battery is too low. This may be a fault with the battery pack or charger/cable. Try switching charger and cable to see if that helps. Good luck wth the fix.
2017-9-24
Celsus
DennisMurry08 Posted at 2017-9-24 11:04
The alternative to focus fixers if you are in a hurry is to have the lens frame 3d printed then install your own lens.
2017-9-24
DennisMurry08
Celsus Posted at 2017-9-24 11:25
No...I wish it was that easy...seems I've zeroed in on the connection with the headband....when it shows the single green I disconnect and reconnect and then it works.....so I'll see if it keeps working. I'm probably going to send back in for a fix per Thor but enjoying the flying weather right now
2017-9-25
DJI Thor
Thanks for the info, I had forwarded to the engineers and will also get back to you once I heard something.
2017-9-27
DennisMurry08
DJI Thor Posted at 2017-9-27 03:28
Thanks...they should have them for us guys who have 1000's and 900's too..... I know you can't get the flights but we should be able to show we have more than what shows....just sayin....ok, maybe an ego thing...and a ton of money with DJI.....
2017-9-28
DennisMurry08
Hear anything back yet? Thanks
2017-10-5
DJI Thor
DennisMurry08 Posted at 2017-10-5 15:57
I am so sorry, not yet. I had once again escalated the case.
2017-10-9
DennisMurry08
DJI Thor Posted at 2017-10-9 22:33
Lol...it’s just a ego thing......no worries
2017-10-10
DennisMurry08
Ummm....anything on the icon yet?
2017-11-4
DJI Thor
DennisMurry08 Posted at 2017-11-4 19:47
Our engineers promised me that they would help to handle it. Let me knock them again.
2017-11-8
DJI Thor
Hey, it appears finally.
2017-11-9
DennisMurry08
DJI Thor Posted at 2017-11-9 20:04
It’s not there.....
2017-11-13
DJI Thor
Huh? I can see it actually. See screenshot below. Maybe you can try to resign again. goggle icon.png
2017-11-14
DennisMurry08
DJI Thor Posted at 2017-11-14 01:59
Huh? I can see it actually. See screenshot below. Maybe you can try to resign again.[view_image]
Well...it went away...now it’s back...you must posses magic...
2017-11-14
Chuck1026
Flight distance : 1213816 ft
I bought a pair of goggles in May... used them a little but I didn't like them and decided to sell them on eBay. The buyer has an Inspire 2 and is having difficulty with head tracking... now he says they don't always power up. They were like brand new when I sold them.  Is there any way DJI can help me help him?
2017-12-23
fanse11feaa2
Flight distance : 464721 ft
Anyone know how to head tracking using dji goggles and a dji inspire 2
2017-12-24
DJI Thor
Chuck1026 Posted at 2017-12-23 19:35
Hi mate, could you please ask the buyer to contact us with more details directly? They can also contact us via online chat directly. Here’s the link to contact us: http://www.dji.com/support.
A video of this case can make a big help for understanding. Appreciate it.
2017-12-25
DJI Thor
fanse11feaa2 Posted at 2017-12-24 15:49
Hi, please refer to the tutorial below. Head Tracking is introduced at 1:54. Please note that head tracking is only available when connecting the RC via USB cable for Inspire 2. Hope it helps.
2017-12-25
Chuck1026
DJI Thor Posted at 2017-12-25 03:04
Thanks DJI Thor! I previously shared this forum thread and the repair link. Hopefully there's an easy solution. If not, I hope the warranty will help! He's pretty frustrated.
It looks like he may have posted on here as well about his Inspire 2 / Googles head tracking issue. He told me he also had power up issues.
I agree he needs to work with you directly. Thank you in advance for helping him!
2017-12-25
DennisMurry08
The problem with my goggles is as the video shows...when you first try to power up and press the power button it turns the first green light on before you have a chance to push it twice. This makes it so the goggles won’t power up after the second push . I believe the issue is in the band connection to the goggles..I can flip the goggles up,and down..even push them in more and it will act normally...lately I just disconnect the goggles from the band and plug them back in..90% of the time it works..the other 10 I repeat.
2017-12-25
DennisMurry08
Hope this helps.
Got the focus fixers..they work perfect as you said...quite happy and I let Chris know too...thanks for the heads up
2017-12-25
fanse11feaa2
How can I ask a question
2017-12-25
Chuck1026
DennisMurry08 Posted at 2017-12-25 15:00
I hope DJI fixes yours for you. Did they offer a free repair? Intermittent issues are difficult to solve for sure.
2017-12-26
Chuck1026
fanse11feaa2 Posted at 2017-12-25 15:37
Your posts appear on this thread, so just make sure to ask your question and provide plenty of detail. That's the key. I saw DJI Thor is watching, replying and sharing suggestions to resolve.
2017-12-26
12Next >
