180 pano fail on dji go app
985 10 2017-8-13
skull leader
Mexico
Topic^
I keep attempting to do the 180 pano shot on my spark. It keeps failing on the dji app. All firmware updated. Any suggestions?
2017-8-13
fans56cfd429
Flight distance : 69633 ft
More details needed.
2017-8-13
Perlbo
Flight distance : 150951 ft
Hi, same problem here. Found Solution. It seems pano stichting only works, when spark connected to App. Then Go to play bottom right. There you can stich pano. Dont understand why this is not possible without Connection.
2017-8-13
Jimmy hoffa
Flight distance : 1824291 ft
Because u have to download all images off of spark in order for it to be stitched....so it needs to be on to transfer data (download)
2017-8-13
Perlbo
But  series and single Shots are automaticly shown in App. That is confusing.
2017-8-13
Perlbo
Mean showing automatic in app Editor tap.
2017-8-13
TMUSVI
Flight distance : 228891 ft
U.S. Virgin Islands
I had 1 pano work great 21 shots and then the next 1 failed will try again
2017-8-13
DJI Diana
Flight distance : 2408 ft
Please provide more details about this issue. Besides, what is the APP version and what mobile device are you using?
2017-8-13
skull leader
I can see a regular pano shot on the dji app using iPhone 6 Plus on most current iOS.  I have all the current updates on iPhone and dji go 4 app. The 180 pano shot would do 21 shots but when I go to see them on the editor play button it would load for awhile and then fail. I have the spark on while I transfer the shot on. I believe the stitching failed. Hope that helps. Newbie here.
2017-8-15
Net2-tv
Flight distance : 4606 ft
problems with pano horizontal / vertical / 180
all upgraded spark version remote controler version up to date only when 1 meter above the ground it works on all pano's setings
it say after higherup  canot capture  pano  fail
normal fhotos works fine
and used the recent app dji go 4
maybe can some answer whats wrong at this point
thanx
2019-2-12
Net2-tv
some i forgot to tel
at 120 meter high it says capure fail at pano  H / V / 180  / normal foto;s works fine at 4k
video works fine 1080P plus i have a super quick micro  sd card 100 mb sec write + download
2019-2-12
