Active Track Test
635 12 2017-8-13
theGrindLab.com
Flight distance : 1375846 ft
Tested the Active Track feature from 60+ feet up on a person skating (longboard) yesterday. From top to bottom was a difference of about 100 ft and the Phantom tracked perfectly. I did take over height controls at one point so footage would be of a closer view of the subject, but the best footage was when the Phantom had full control. I can also say that the Phantom was tracking at 22.6+ MPH. I didn't check top speed after the flight, but I know at one point it was going at least the speed mentioned.
2017-8-13
BagoDJIoperator
Flight distance : 1077608 ft
Wow that looks great, nice work
2017-8-13
theGrindLab.com
BagoDJIoperator Posted at 2017-8-13 11:30
Thanks. It was all the P4P doing the heavy lifting though. I simply pressed the record button.
2017-8-13
BagoDJIoperator
theGrindLab.com Posted at 2017-8-13 11:39
I hope to get some cool videos i just need to get the time, I been way too busy
2017-8-13
hallmark007
Flight distance : 9827923 ft
Great job thanks for sharing.
2017-8-13
theGrindLab.com
hallmark007 Posted at 2017-8-13 14:46
Thanks, Sir Hallmark.
2017-8-13
DJI Susan
The video looks great! Thanks for sharing. Enjoy it and happy flying!
2017-8-13
Genghis9
Flight distance : 961 ft
Looked good, but I have to ask…
A few times the drone appeared to overtake the target and put them at the bottom of the frame or nearly out of frame.  Is that because of a particular setting you made, or just how the craft was performing the track?
In addition, were you aware ahead of time of the high power lines that you encountered near the end?  If so, did you calibrate the altitude in advance or is that where you were making real-time adjustments?  Where were you in relation to the flying of the drone, back at the start area or in a follow on vehicle or?
Thanks
2017-8-13
theGrindLab.com
Genghis9 Posted at 2017-8-13 21:18
Looked good, but I have to ask…A few times the drone appeared to overtake the target and put them at the bottom of the frame or nearly out of frame.  Is that because of a particular setting you made, or just how the craft was performing the track?
In addition, were you aware ahead of time of the high power lines that you encountered near the end?  If so, did you calibrate the altitude in advance or is that where you were making real-time adjustments?  Where were you in relation to the flying of the drone, back at the start area or in a follow on vehicle or?Thanks
Once, the AC overtook the skater because I was manually controlling speed. The other times it was due to the AC itself. This was my first attempt with it, so I have not done any tuning aor set any specifics. I would assume the results will be better after I know better how to use Active Track. I could have manually decreased speed or manually adjusted camera angle too.
We had taken the run once before, so I was aware of the power lines. Also, because Active Track only auto-adjusts for height when following UPHILL, the AC was far higher than the power lines by the time the skater made it to the bottom of the run. I had manually decreased height some by then though. I was in the passenger seat of a vehicle following the skater. We were probably 50 meters or so behind him, but to follow him in a vehicle was not necessary at all.
2017-8-14
Genghis9
theGrindLab.com Posted at 2017-8-14 06:26
Once, the AC overtook the skater because I was manually controlling speed. The other times it was due to the AC itself. This was my first attempt with it, so I have not done any tuning are set any specifics. I would assume the results will be better after I know better how to use Active Track. I could have manually decreased speed or manually adjusted camera angle too.
Thanks!
Appreciate the feedback, all good to know
Enjoy, Fly Safe
2017-8-14
DJI Joe
Glad to see someone else using DJI aircraft to film downhill skating. I've taken both the Mavic and P4P with me, but I always get distracted by actually skating and usually only film 2 runs or so.
2017-8-14
theGrindLab.com
DJI Joe Posted at 2017-8-14 10:19
Man! Skating/Longboarding is the single most important reason I started buying DJI. Since I am done with my studies finally, I can put more time on learning to shoot better. Expect more. You can see more of our old Phantom 3 footage on our Youtube channel (thegrindlab).
2017-8-14
DJI Joe
theGrindLab.com Posted at 2017-8-14 10:50
Keep posting here. You have my full support! Skate and fly safe.
2017-8-14
