"lower_version_boardnum" in the ac name in app?
212788 212788 2017-8-13
BumblerBee
Flight distance : 639764 ft
Norway
At times the flight logs page, when I scroll to the aircraft part, shows text "lower_version_boardnum" instead of my AC name. This text string also seeps into the logs, so some logs will show "BumblerBee", and some will show "lower_verion_boardnum" in the under the Mavic icon in the upper left corner of the flight log player
Has anyone else experienced this problem? I submitted a bug report on this.
2017-8-13
DJI Thor
Flight distance : 13602 ft
Could you please provide us with the screenshots of this case?
2017-8-13
BumblerBee
Norway
DJI Thor Posted at 2017-8-13 20:41
Here they are:
http://imgur.com/a/JAh1M
2017-8-14
DJI Thor
Thank you, could you also offer a screenshot of the "BumblerBee" in the upper left corner? What are your mobile device and DJI GO 4 app version? I had forwarded this case to our engineers, and will reply you once I heard from them.
2017-8-14
BumblerBee
Norway
Here are the requested images. One more with the wrong text, then two, where the app "added" another letter: '~' and 't'. And finally the correct representation. This looks like a case of buffer overrun to me.
http://imgur.com/a/CtXMo
I use iPhone 6s Plus and DJI Go  v4.1.5 (2952)
2017-8-15
BumblerBee
Norway
And today I am "BumblerBeel"
2017-8-16
DJI Thor
BumblerBee Posted at 2017-8-15 09:45
Thanks for your feedback. Could you please sync your flight records and then provide us with your DJI account? We would help to check more about this. Appreciate your assistance.
2017-8-21
BumblerBee
Norway
And today I am again "lower_version_boardnum".
Am I the only one to have a problem with the name changing after flights/syncs?
2017-8-27
MARSAN
Flight distance : 966978 ft
Belgium
BumblerBee Posted at 2017-8-27 09:38
If I were you, I would uninstall DJI GO 4, restart the mobile device and then re-install DJI GO 4.
2017-8-27
BumblerBee
Norway
MARSAN Posted at 2017-8-27 10:13
Would I lose my settings or are they stored on the RC?
2017-8-27
MARSAN
Belgium
BumblerBee Posted at 2017-8-27 10:32
You may lose a setting or two, difficult to say, also make sure your maps are still downloaded.
Just go through the settings and write down what you need, or better still, take screenshots of everything.
You will lose nothing that can't be recovered.
2017-8-27
DJI Thor
I had received your PM and replied you. Please check. And for the question below, MC settings will be stored in the aircraft, so it might not be changed. But it might change the camera settings to default. So you can note down the camera settings now and then reinstall the app.
2017-8-27
Jyunte
Flight distance : 2103150 ft
I am also seeing the same issue. Sometimes I'm lower_version_boardnum,m other times I'm Jyunte.
2017-8-29
DJI Thor
Jyunte Posted at 2017-8-29 16:25
Could you please sync your flight records and provide me with your DJI account so I can forward to our engineers to check more? Thank you in advance.
2017-8-31
Mafia16
Flight distance : 26490948 ft
Dominican Republic
I have the same error with multiple devices like the mavic and P4 can you guys help me? all my flight are sync you can check.
2017-8-31
andreaaltieri
Flight distance : 47336 ft
Hi, I have the same issue. And when I have uninstalled and reinstalled the DJI Go 4 app I have lost all my precedent records...
2017-9-1
Jyunte
Today my Mavic is "Mavic ProkQ". App added "kQ" to the end.
2017-9-1
Jyunte
DJI Thor Posted at 2017-8-31 03:52
I did as you asked, and sent you a PM with my account information.... I've heard nothing so far. Any updates on this issue? Sometimes everything is fine, other times I see "lower_value_boardnum", sometimes I see my Mavic's name, with extra characters added.
2017-9-5
andreaaltieri
Since several days now I have always and only "lower_version_boardnum". The name given to my Mavic I don't see it anymore. And my previous records have disappeared since I reinstalled the app, even though I had synced them. There is anything that can I do? It's annoying to always see this name...
2017-9-5
DJI Thor
Jyunte Posted at 2017-9-5 00:02
I had forwarded the update to our engineers to look into. Will reply you once I heard from them. Thanks for your feedback.
2017-9-5
DJI Thor
andreaaltieri Posted at 2017-9-5 00:45
Had you also tried to sync again? They should come out when you sync again if the records were synced successfully before.
2017-9-5
SteWong
Flight distance : 3119432 ft
I have this issue too, it happens since I start using CrystalSky. Some of my flight put under the aircraft name "lower_version_boardnum".
2017-9-5
andreaaltieri
DJI Thor Posted at 2017-9-5 03:36
Yes, but it didn't work...
2017-9-5
Mafia16
Dominican Republic
any news when DJI is going to fix these problem. is messing my flightlogs
2017-9-14
DJI iOS Team
DJI R&D Squad
May I hv ur dji account? I need to check ur synced records for details.
For old version app, there is no guarantee for fetching the drone's name, resulting in lower board num display
2017-9-27
fly_low
Flight distance : 76985 ft
Taiwan
im having the same issue on two different devices
2017-10-9
fly_low
Taiwan
22426134_10102582912789173_1270102326_o.jpg 22375612_10102582912794163_1365789000_o.jpg 22404029_10102582913248253_1759370672_o.png 22375446_10102582913407933_1266022237_o.png
2017-10-9
fansf05a0fed
Flight distance : 46348 ft
I was wondering if there is a fix for this? I just recently bought a spark, and I am having the same issue where a few of my flights are logged under the fake device name lower_version_broadnum thanks in advance.
2017-11-9
kamote
Flight distance : 13835 ft
Indonesia
Same issue with my mavic pro. I just noticed today after a flight in a different location.
2017-11-22
fanse0e4182d
Flight distance : 467103 ft
Israel
Similar issue with my spark today,
Totally lost communication to the drone within 10m distance.
Reconnected after about 15sec  and found that the flight session was split into 2 separate ones, second one showed lower version boardnum in the name.
2017-11-24
fans7dfe7fdd
Flight distance : 97690 ft
New Zealand
Hi guys,
I've got the same problem with my DJI GO and Inspire 1 – any fix for this please?
Or is there a way to combine aircraft/flights to retain the stats, but get rid of the dupe aircraft?
Thanks team!
2017-12-5
Phui
my spark lost control within few meters and crashed onto a tree, after checking flight log, found this strange "lower_version_boardnum", any idea? is there anything related to lost control?? thx
2017-12-12
Otto Spark
Phui Posted at 2017-12-12 20:58
I too have noticed the “lower_version_boardnum”. At this point I have three listed under my flight logs all from using a newly purchased spark. I decided to google it right after my Spark lost control. I was flying with the controller at the time. Was about 20m away when it just flew off and crashed into a tree at 30m altitude.
2017-12-19
fans37db881d
Flight distance : 1469278 ft
I am getting the same thing. It will not let me fly very far. It sets my hight to zero and well as my distance. I had reinstalled the GO app and it works fine untill sysc flight log. Back to the bug.
No more syncing for me.
2017-12-31
giaxxon
I just found this thread on a google search for the same issue flying a Spark. Aside from a few video cut-outs at pretty close range I didn't experience any control issues and Lower-Version only logged 3ft at 0.2mph.
What does seem weird is that one of my flights got cut up into a couple segments on the log, but I chocked that up to entering "quick shot" or "active track" modes, which I was fooling around with.
Otherwise everything is on the latest firmware and I had no issues.
2017-12-31
ibuyufo
Flight distance : 819098 ft
I saw this entry as well with only 1 flight on record.  When I tracked it down, it was from the Mavic.  Is there any fix to this?
2018-1-14
fansb0a66670
Same here. Very short flight lost all control of aircraft. It self landed, and shut down.  Now it wont start back up. Said it was still in flight after landing. Lefs shut off battery was still lit up at 75% No led lights will even flash upon startup anymore.  Im dead in the water. Aircraft disconnected shows on app. Cant re sync controller w aircraft. WHAT A MESS.
2018-1-14
Lucas775
Flight distance : 50642090 ft
What?!!!!!!!!!!!! I have the same "lower_version_boardnum" showed up when I got my inspire, I have a regular one that I named inspire 1 with 36+ of my flights and 3 flights on "lower_version_boardnum" what is this all about?
2018-1-14
fansb0a66670
Still no fix... this “bug” ot what ever it is. Killed my phantom. When i power on, i get the first initial 3 -4 beeps. Then nothing.  No LEDS light up, no gimbel action. No light on gimbel.  Just a big boat anchor.
2018-1-14
doomickCZ
Flight distance : 121706 ft
Czechia
I have the same issue with "lower_version_boardnum" is there any solution?
2018-2-9
