Mavic Pro Flight Distance
5370 21 2017-8-13
Drop Zone Media
I am having a challenge with my Mavic Pro. No matter what distance settings I select it won't go past a short distance, and high is also effected.
beginner mode is off, multi flight modes are enabled.
Anyone offer some advice?
2017-8-13
MARSAN
Flight distance : 966978 ft
Belgium
Did you log into your DJI account in DJI GO 4?
2017-8-13
Drop Zone Media
MARSAN Posted at 2017-8-13 13:43
Not on this flight, I will give it a shot and see.
2017-8-13
Drop Zone Media
Drop Zone Media Posted at 2017-8-13 13:46
I logged on, and didn't see where to make a change.
2017-8-13
Drop Zone Media
Just flew with it Logged in and no difference,  I changed the settings and can't fly past about 150 feet.
2017-8-13
PY4CK
Flight distance : 6443990 ft
Brazil
Check the video below. You might be on beginner's mode.
2017-8-13
Drop Zone Media
Checked that, and its off!  Its one of the first things I checked.  Re-did all the distance and height settings.  Like its stuck in beginners mode but its turned off
2017-8-13
ghostrdr
Flight distance : 1272723 ft
Drop Zone Media Posted at 2017-8-13 14:22
I assume you are using the controller and not wifi. There is another setting... Enable Max Distance, check to verify that is enabled.
2017-8-13
Drop Zone Media
Yes I did that, Yes using the controller. Just found out the Latest update is the challenge. It limits the height and distance via the restricted areas.  I guess my house is in one of those areas.  I will have to check in an area that is not inhabited.  Thanks for your input
2017-8-13
Tombolian
Flight distance : 675958 ft
How are you coming to the conclusion that you live in an area that's restricted because it's inhabited?
2017-8-13
DJI Thor
Flight distance : 13602 ft
Did you get any prompts when you flew to the max distance of your drone? Had you updated your drone and RC's firmware?
2017-8-13
MARSAN
Belgium
Drop Zone Media Posted at 2017-8-13 15:09
Are you saying that you're flying your Mavic with the RC only, i.e. without a mobile device attached to the RC?
If that is the case, then indeed the flight height is limited to 30 meters and the flight distance is limited to 50 meters.
You must attach a mobile device to the RC and you must have signed into your DJI account in DJI GO 4 at least once to be able to fly your Mavic higher and farther than the limits mentioned above.
Exit Beginner Mode as well.
Could you please confirm this?
2017-8-13
luxiaoning
Flight distance : 8743 ft
Hi Mate, please check whether your APP is the latest version. I experienced the same issue, and fixed it through updating APP. Have a try....
2017-8-13
Drop Zone Media
luxiaoning Posted at 2017-8-13 23:39
I updated, and now I have un-installed the App and re-installed it.  Hope this fixes the challenges
2017-8-14
Drop Zone Media
MARSAN Posted at 2017-8-13 22:20
I am not in RC only, Phone attached.  Have flown many times and no problems, Beginner mode is off, and logged into my Account.  I have uninstalled the Go4 app and re-installed it.  Hope this fixes the problem
2017-8-14
Drop Zone Media
DJI Thor Posted at 2017-8-13 20:11
I update when Prompted, I have flown many times and no challenges.  Its after the Last update, and restricted zones updates that I have this problem.  I have doubled checked my settings.  Now I have uninstalled the go4 app and did a re-install.  Have also logged into my dji account.
2017-8-14
DJI Thor
Drop Zone Media Posted at 2017-8-14 19:17
So you are living in a restricted area, right? If so, the limitation of the distance can not be changed unless you apply for unlocking.
2017-8-15
MARSAN
Belgium
Drop Zone Media Posted at 2017-8-14 19:13
Check in DJI GO 4 whether RC and AC have the latest firmware versions installed and that they are identical.
In the DJI GO 4 tap "Me" at the bottom right, then the gear wheel (Settings) at the top right.
Make sure you see a red "Sign Out" in the Settings.
For what it's worth, tap "Reset Beginner's Guide" and then OK.
Now I'm out of ideas...
2017-8-15
Drop Zone Media
DJI Thor Posted at 2017-8-15 00:07
I don't think I am, but the Mavic must think I am, because it won't fly very Far.
2017-8-16
Drop Zone Media
Great news and thanks everyone for helping me with my problems!  After doing a re-install the Mavic (Skeeter) is working great.
2017-8-16
DJI Thor
Drop Zone Media Posted at 2017-8-16 18:32
Thanks for the feedback. But I am curious about what had been reinstalled? The firmware of the drone or the DJI GO 4 app?
2017-8-17
Drop Zone Media
I un-installed the Dji Go4 app and did a reinstall.
2017-8-17
