Geebax
funnyman850 Posted at 2017-8-13 19:01
Only have 2 pins fitted and I replaced the ripped anti-vibration pieces after the crash. A couple were broken before and they worked fine. I did also have to use a ziptie to keep the shell together which leads me to think it might be a balancing issue. I just put one on the opposite side and will see if it works tomorrow.
I should not think the tie would cause that, but try it anyway. The best trick is to fire up the aircraft on a wooden table, with props and all, but don't take off. Then look carefully to see if the camera is vibrating. Next, take off and hover just over your head and check it again. Also touch the camera to see it it is vibrating. Be very careful of the props while doing these tests.
