fans5d9349b7
DJI Diana Posted at 2017-8-14 02:07
Thank you, I just checked it, it seems that you only exported the flight controller data, no black box data and no flight controller log data. Is it able to export the rest of data about this flight for further analysis? Thank you in advance! DJI Quick Tips - Spark - Exporting the Flight Data
I'll do that when I get home - if the logs are still there from weeks ago.
Could you please ask your engineers if the Spark is capable of sending a shut down command to its battery? I mean, I can't see any reason the Spark would ever need to turn its battery off, the battery should be intelligent enough to turn itself off in the case of a malfunction or low battery status, or with the button press combo. My Spark totally shut down, and I had to turn the battery back on. At 70%. |
