Vyborny83
Flight distance : 166014 ft
Czechia
Well, there are actually two problems. The first one is that if you connect the RC to your phone via the OTG cable you won't see the channels. It is a well known problem that DJI never solved (as well as official OTG support ...). If you disconnect the cable, you should see them again.
The second problem you face is that in Israel, the 5.8 GHz band is reserved for military and therefore you shouldn't use it at all (which is impossible without the OTG cable as you cannot use the 2,4GHz for both the phone-RC and RC-Spark connections at the same time ;) ). |
