Mavic Home Point
1270 6 2017-8-14
QuadKid
Flight distance : 482349 ft
Well I finally got my local maps to work, went out this morning, didn't get the fimilar "Home Point has been Updated - Please check it on the Map" had 18 satellites good GPS signal
I know I can manually set the home point, I have done it once before just don't remember how? If anyone knows it would be much appreciated, many times I fly with no WiFi available, as I understand it, setting the home point manually sets the point to the current GPS location?
2017-8-14
Tango_B
Flight distance : 2891473 ft
At the main screen within the DJI Go 4 app --> swipe one finger across screen to the left --> tap the HOME POINT AIRCRAFT button to set it's current location as home point, or tap the HOME POINT ME button to set the remote controller location as home point.
2017-8-14
QuadKid
Tango_B Posted at 2017-8-14 05:28
Thank you very much Tango
2017-8-14
Tango_B
QuadKid Posted at 2017-8-14 05:44
No problem - happy flying!
2017-8-14
DJI Thor
Flight distance : 13602 ft
Like Tango_B mentioned, it is on the Flight Controller Settings. But I wanna confirm that did you noticed was there a green point which indicated the Homepoint on the map? Would it be that you shut down the audio?
2017-8-14
QuadKid
DJI Thor Posted at 2017-8-14 18:21
Hey Thor, did not have green Home Point Icon, I'm using Crystal Sky Monitor, audio is on I get "Take off"
voice indicator will try again this morning and let you know.
Thanks
2017-8-15
DJI Thor
QuadKid Posted at 2017-8-15 01:09
Thanks
Thank you. Looking forward to your feedback, if the problem persists, would you mind taking a video of this case?
2017-8-16
