You are having difiiculties to keep the drone straight. That's normal with the standard yaw settings. Sports mode is just too fast.
You can adjust that in the Expo settings. For that matter switch on the remote into S mode. Then you can adjust it.
It took me a while to figure out that yaw settings for P and S mode can be set separately ;-)
Eric13 Posted at 2017-8-14 23:13
Nah they just caught me by surprise was not expecting them lol
do not use sport mode for video normally just wanted to catch em.
Thanks for tip though
jon
Hi there would you mind giving some more details on this please. Where do you access these settings? Is it possible to adjust acceleration and deceleration also? Thanks.
phantom_of_the_ Posted at 2017-8-17 08:12
You might want to check this out to get a better understanding:
What all the YT experts who give advice on yaw settings do not mention is that you can set separate
values for Sports mode and P mode - the 'normal' mode. (Setting the RC to Atti are the same settings like in P mode)
Go4 app:
Go to Main Controller Settings, scroll all the way down to Advanced settings and enter those.
Under EXP (Expo settings) you can adjust how fast the AC reacts to different stick inputs.
If your remote is switched to P mode, it says 'Normal' under EXP.
No switch the remote to S mode and it says 'Sport' under EXP. There you can set your personally preferences for Sports mode only. I have set the Rudder to 0.15. This way I can still control the yaw smoothly at high speed.
Acceleration/Deceleration you adjust in the Throttle settings.
