I give up...how are you doing this?
Specifically, I've assumed that many of these tight backup shots were done flying forward where you can see and avoid with the camera looking forward, because it was clear the operator was not in a positon to see LoS or even have a good angle on the approach. Then in post, the shot was reversed to get the back out shot look.
However, your demo and tutorial does not seem to show that? So, how are you maneuvering this craft in such tight spaces when clearly you can't see enough to make the control inputs necessary to remain stable and not hit anything and the camera is looking backwards...can't figure this out? Sure, initially in the demo through the trees, you could see enough to fly it safely but the latter half of the flight through had to be so occluded that I don't believe you could maintain full sight. Please share this industry secret...Thanks
