ImHereToCrash
Flight distance : 5381368 ft
i have only 1 experience flying under a bridge, i didn't record it because, to be honest i forget to record 80% of the time, but i will say it was a success, it does dive headfirst into atti mode, the spark is definitely the wrong drone for bridges, i suggest staying closer to the ground than to the top, make sure your within VPS rage and like 10-15 feet off the ground or water and go slow.. if you can use tripod mode.. slow and low.. sounds counter intuitive if you want to avoid water, but if VPS can track it, then your spark will remain more stable even in atti... as for where signal from RC will get lost, ..dont be on the bridge, that will shield it.. be at same level..
final point, spark ..at the moment is the wrong drone for these types of shots, i suggest a mavic pro or something higher end that has better VPS and 3D sensor system and can use flight autonomy better from within the app like following a line or something.. |
