Battery water protection circuit?
1438 6 2017-8-15
P4P+
Does the Phantom battery have a water sensor circuit that makes the battery inoperable when the battery gets wet? Or, does the battery stop working after getting wet from one of many electronic parts failing after getting wet? I only ask because a few months ago my battery got wet and stopped working so I disposed of it, even though it still showed a full charge on the multimeter.
2017-8-15
Dobmatt
Flight distance : 1831050 ft
Pilots don't know such things, they fly instead. All they need to know is that liquid water or moisture inside battery may - and eventually will - cause an catastrophic failure during flight. You must ask mechanics in your hangar how this protective behaviour works ...
2017-8-15
ALABAMA
Flight distance : 10442687 ft
Water and drones (any part)  don't mix
2017-8-15
Nigel_
Flight distance : 388642 ft
ALABAMA Posted at 2017-8-15 08:13
2017-8-15
ALABAMA
OK.......try this with your drone, post the video, and I'll be a believer.
2017-8-15
DJI Susan
I would recommend you do not allow the battery to contact water. The watered battery may even lead to an axplosion.
2017-8-15
Cetacean
Flight distance : 2528264 ft
Aloha Nigel,
     Yeah, I liked that video when I first saw it to.  Pretty wicked!
Aloha and Drone On!
2017-8-16
