This is the only way I can get the restrictions to go away. Can someone Please Help?
1) Sync your flight logs.
2) Log out of the app.
3) Uninstall the app.
4) Re-install the app.
5) Login
When I change out batteries I have to do all 5 steps again plus login again.
After all of this I can fly normal again. I don't mind logging in. I don't do anything wrong. Just wish to have a easy way to go flying.
This was after I decided to do all the new updates. I like to keep everything updated. This is the first problems I have had out of all the
updates I have installed.
May I know which type of mobile do you use? IOS or Android? How about switching to the other one? Also, I would recommend you to restart the APP as well after changing to another battery.
Thanks Susan,
I use IOS, Ipad10.5. So if I have a android devise you are saying to try and see if android works better for now. Thanks again, I will try this on my next flight.
