Has anyone found a good place to fix the Marco Polo 'Tag' unit on the Mavic Pro? I have considered the back end of the drone just below the rear light on the main body but not sure if this will interefere with any electronics? Thanks
I believe the GPS chip is at the back. I am thinking of purchasing a similar device and it seems the best place to plant it is on the front at the top to avoid any possible interference. I studied the exploded views of the Mavic and although an unsightly position it seemed to be the best. I am just going to put self adhesive velcro strips on the top. Is the Marco Polo any good? Keep looking for one but pretty rare here in the UK
FlyingLocksmith Posted at 2017-8-19 07:44
I have ended up putting it on the rear of the Mavic body just above the rear light so that the antennae of the Marco Polo will not interfere with the camera - as it might have done had I put it on the front. I used a small strip of Velcro and due to the light weight of the Marco Polo it sits there just fine (with the antennae pointing down to avoid the rotor blades). The antennae bends a little when sitting on the ground but this is not a problem because the antennae is very flexible and it does not harm. It has not interfered with the performance of the drone at all. Thanks everyone for your interest.
mpwobbly Posted at 2017-9-8 13:37
Can you please post the picture of MP mounted on Mavic? Thnx!
Hi - sorry for the delay I haven't been back to the website for a little while. As you can see the TAG doesn't interfere with anything and sits just nicely where I have it on the back. The TAG is held on by Velcro.
Here is how I mounted my Marco Polo tag. I have yet to try it out however.
The velcro is split between the battery and the Mavic as seen in these 2 pictures.
I have no idea if there will be any interference based on the mounting location.
Goldchucker Posted at 2018-5-31 08:34
I have since moved the tag to the top front. I found out that the GPS is located in the back and the tag in this position could cause interferance. I painted it orange for better visability in the even it fell off during a potential crash. I have not experienced any issues with the tag being mounted on the front. This newer style has the antenna located on top rather than on the side.
DJI should consider installing in their next round of drones (at higher selling price), Find Me beacons.
Separate power source that transmits GPS coordinates, emits sound that can be located by human ear, and ultra-bright flashing LED.
Goldchucker Posted at 2018-7-2 16:47
My main concern was trying to keep the antenna from hitting the blades and I personally have not had any GPS interference issues with where I have put mine. The transmission range of the tracker is quite a distance and it suggests to me that moving it a couple of inches to the front might have minimal effect on any interference. Having said that though, I am in no position to dispute your reasoning and whatever measures we take can possibly be best addressed by someone from the DJI technical department. I confess that it has made me rethink this. Love the orange day glow idea. Thanks
