zoutv1
Flight distance : 174738 ft
Bill in Ohio Posted at 2017-8-16 06:20
I have a Samsung S7, latest Android OS 7 update was August 1, 2017 to build ...BQG1, Mavic Pro Firmware v 01.03.09 with DJI GO4 v 4.1.5 and since then I have been running without any problems. I changed the phone settings: DISPLAY > MODE to BASIC as well as DISPLAY > RESOLUTION to 1920 x 1080. That solved most of my problems in earlier versions as well as this. Samsung has a note that pops up when you switch to fancy display modes and higher resolutions that some apps may not work and it will drain the battery faster (ie. more processing being done). Samsung takes the latest Android OS updates and then tweaks them for their special features before releasing it. My phone still says I am on 7.0, but they have done about 3 updates since then. Your Mavic does best when you have lots of processing power to feed it's massive requirements. I also turn off wifi and blu tooth when I fly. Some turn on Airplane mode. Hope this helps.
Did you ever try running the app when your phone OS was version 6.x? I keep on getting prompted to upgrade my phone OS by Verizon for months now, but I'm leary to upgrade. This might force me though.
Thanks for the tips!! |
