flighttime1
Flight distance : 906352 ft
linkcolnK...
Your example seems a bit extreme from what most have had to deal with. The typical problem with the Osmo/X5 is that if you try and pan, it will lose the horizon and get stuck with about a 15 degree angle. The fastest correction, I've found, is to triple click into selfie mode and then double click back to normal. This is something that should have been fixed long ago but still exists, albeit, at a lesser degree than before. |
