Phantom 4 RC not fully charging
1000 7 2017-8-17
fansd1d40f34
Flight distance : 1330495 ft
As many others are experiencing, my P4 RC is not fully charging.  It would only charge to 92% after 2 firmware updates ago.  Now, after the last firmware update it only goes to 81-85%.
I called DJI Support and here is what they recommended:
Refresh the RC software using DJI Assistant.  Then try to recharge.
If that didn't work, try a deep discharge/recharge.
Has anyone already tried these proposed resolutions?  Did it work?  Did it make things worse?
I'm hesitant to try as I don't want to make things worse.  My P4 flies well and I still can get a decent charge on my RC.  I just would like to get a full RC charge.
2017-8-17
DJI Susan
Is the fully discharge/recharge working? If no helps, I would recommend you to start a repair case and send it in for diagnosis: http://www.dji.com/support
2017-8-17
fansd1d40f34
DJI Susan Posted at 2017-8-17 18:12
I did not try the discharge recharge.  Based on other stories I've read around the forums I'm afraid to do so.   I have some work I have to to in the next few months and cannot afford down time should this cause harm to the RC.  I'd be more willing to try it if others who've tried would share some success stories.  To this point no one has replied other than you.
2017-8-18
DJI Susan
fansd1d40f34 Posted at 2017-8-18 08:55
According to your description, it might be the hardware issue, please consider my suggestion when you are available to send it in.
2017-8-19
fansd1d40f34
DJI Susan Posted at 2017-8-19 00:45
How does one refresh the P4 remote control software?  I tried to downgrade using the Go4 app using my iPad air2 and it just fails trying to download version 1.8
I upgraded again (P4 remote) to the latest remote firmware 1.9.3 today released (9/13/2017 or close to that date) and now my remote only charges to 67%.  Everytime DJI upgrades the remote firmware it lowers the level I can charge my battery.
2017-9-13
DJI Susan
fansd1d40f34 Posted at 2017-9-13 17:07
The RC is not available to refresh the firmware. I still recommend you to send it in for repair.
2017-9-15
fansd1d40f34
DJI Susan Posted at 2017-9-15 02:40
It's on it's way to DJI for repair.  Thanks for your help.
2017-9-16
DJI Susan
fansd1d40f34 Posted at 2017-9-16 04:54
You are welcome! Please PM me your case number, and I'd like to follow up the case for you.
2017-9-20
