Getting out of beginner mode in the Goggles?
1496 3 2017-8-17
NomadRT
Flight distance : 1669012 ft
When I plug my phone into my remote for the Mavic and fly with the googles, I'm in regular mode.    When I try to fly with the goggles and just the controller I'm stuck in beginner mode.   Is there any way to turn off beginner mode when it comes to just using the goggles and the remote but no phone?
2017-8-17
DJI Thor
Flight distance : 13602 ft
Just to verify, did you get the prompt that showed you were in Beginner Mode or you get the 30 meters height limitation? If it is the second case, you need to connect your mobile device and connect all the devices together, then you can unplug the mobile device and the limitation will disappear.
2017-8-17
NomadRT
DJI Thor Posted at 2017-8-17 18:12
Just to verify, did you get the prompt that showed you were in Beginner Mode or you get the 30 meters height limitation? If it is the second case, you need to connect your mobile device and connect all the devices together, then you can plug out the mobile device and the limitation will disappear.
The second one.   Thanks for the help!   Will do this today....
2017-8-18
DJI Thor
NomadRT Posted at 2017-8-18 07:06
You're welcome, looking forward to your feedback.
2017-8-18
