tonyhhisc
I just went out for a couple flights, it's daylight and clear weather. First try, it gave me the max flight distance reached. Was very annoyed because I know for a fact this time there can't be any conditions issues. I checked all the signals and everything seemed fine. However, I did keep getting the "Strong interference detected. Fly long distances with caution" --- wonder if that had something to do with it?
Anyway, frustrated, I came back inside and pondered... went through all the settings, turned off "smart return home", turn on/off max distance just to make sure it is OFF. When i turned on the max distance setting I could see there was a max distance of 100 in there. If its OFF , then the distance listed there shouldn't matter I assume. But Just for kicks, I changed it to 500... just in case it's being picked up even when OFF. I also made sure my max height was still set to 500. Everything looked good, as always.
I logged out of the app, closed it, restarted it, logged back in, and started everything back up.
Went outside, and decided maybe the compass needed to be re-calibrated. So I did that.
After all that, I was ready to fly again. I took off, and wala! I can fly WAY passed the previous distance restriction. Great! Only problem still: I don't know what fixed it :/
I guess I can just repeat all those steps if it happens again. But still I need to know exactly what is causing it so i know how to fix it and/or avoid it.
Any insight will be much appreciated!
Tony
