STech - Hathder
Flight distance : 459094 ft
Brazil
I think its normal, i had before the spark the Parrot Bebop, that drone uses 100% digital stabilization on all AXIS, one thing i learn is that its just works 100% when drone are flying, the digital stabilization works comparing previous image with the next and catching info at real time from IMU to compensates and keep stabilization , if drone are perfect steady, theres no previous image to compare and stabilize, so the software make this type off thing like move a little the image and if drone are not flying it dont give real time IMU flight information to digital stabilization, at least, is how Parrot BEBOP stabilization works, and why parrot bebop footages are much better stabilized when drone are moving and not steady in the air.
If a drone uses some type of digital stabilization, it means the sensor size are bigger than final footage resolution, maybe spark sensor are 4K, just take a look at Parrot Bebop example..
FULL sensor photo taken by me with bebop and i will make a frame explaining how it works:
