Defective motor
748 5 2017-8-18
djiuser_cusRdcb
Israel
Hey there, i need some help.
I bought my Mavic about week and a half ago, never crashed it or something.
Today i noticed that 1 of the motors is higher then the other ones which makes it look like a manufacturing negligence, also when im trying to rotate it using my hand it feels a little bit harder then the other one.
In the photos below you can see that the motor is higher then the other ones, and also you can see that the prop on the defective motor is sitting a little bit higher then the other props.
I must say that the drone is flying perfectly, its not affecting the quality of the flight.
But i am really scared beacuse of this, should i stop using the drone until checking this?
Is anyone experienced this problem?
*The defective motor is on the left side of the pics*
2017-8-18
Scott Ferguson
Flight distance : 1425223 ft
That gap would definitely let more dust and debris get into the windings of the motor. My mavic motors are all pretty symmetrical in height.
2017-8-18
DJI Thor
Flight distance : 13602 ft
Could you please provide me with your drone's serial number so I can check for you?
2017-8-18
fansafec110c
Flight distance : 64281 ft
Hello, my drone is exactly 14 min flown then the engine is right rear right. Then the drine has flown into a tree and crashed. The drone was 1 day old. :-(
2017-8-18
Fingers
Flight distance : 1365676 ft
Doesn't look right. I think you are wise to investigate.
2017-8-18
DJI Thor
fansafec110c Posted at 2017-8-18 21:26
Sorry to hear about the crash. I can feel your sadness. Had you reported your case to the support team? If not yet, please connect them and start a data analysis, then send the drone in and we will try our best to help this out. http://www.dji.com/support
2017-8-19
