DRONE-flies-YOU
Flight distance : 1450594 ft
Ex Machina Posted at 2017-8-18 20:27
Agreed, -1 sharpness can certainly give you that effect, especially in lower light. If you used those settings with your Mavic before with success, I'd be willing to bet your previous shots were taken in stronger lighting conditions. Like everyone else is saying, don't use negative sharpening and add some smoothing in post where you have finer control over your detail. Personally I think +1 pushes you into over-sharpened territory, but YMMV.
Normally yes, but it seems "0" is not truly zeroed (it used to be). +1 is the only way to turn off that effect in lower light and vegetation. I tried a bunch of test shots to confirm in the shade or just dark trees & such. |
