Augustus Brian
Flight distance : 397592 ft
As I mentioned on a different thread:
Regarding attempts to photograph/film the eclipse with a Phantom (Mavic/Spark structures are different):
Depending on latitude, the sun will likely be too high in the sky for the extra 30 degrees enabled by the Go4 app option. Since you would be shooting up anyway, the need to even be aloft would seem unnecessary--you could lean the quad back (on a table) and get the sun. (But without any zoom capability, I don't see the reasoning).
But if you wanted to be in the air, you might be able to attach a small mirror below the quad (with OA/sonar systems turned off), such that the front edge would be flush with the Phantom's front legs. That way you shoot the shadow moving over the ground, using the level (or slightly downward) gimbal, then point it downward (into the mirror) to catch totality. And if you get the edge positioned just right, you might be able to catch both the shadow and the sun in the same frame. You might need some testing tomorrow at the same time as the eclipse on Monday.
Also, time lapse would seem unnecessary, as the total time of totality at any location is about 3 minutes.
Keep Smiling,
Augustus |
