Go 4 spark app no map using phone only?
713 2 2017-8-20
Tim1985
Flight distance : 32641 ft
Maybe I can’t find it , but is it possible to check the map after hike point has been set using phone only?
I let the spark set home point , Huber for a minute then manually set phone and sparks home point. Each time the app says check the map. Well the problem is I can not find the map. I know using the R/C , it shows the map.
2017-8-20
DJI Susan
There is no map when you connect the mobile device only due to the limit mobile size and virtual sticks. I would recommend you to control it via RC.
2017-8-20
Tim1985
Thank you Susan. I have a rc on the way , but I believe there should be an option to check the homepoint when using a cell phone or tablet only. Even if it locks the sparks from taking off until back to the main screen. My spark holds its position well but for extra comfort , conforming the location of where the spark says home point is would be extra peace of mind.
2017-8-21
