User Feedback on Firmware Update v01.00.0600
2814 24 2017-8-21
Sparky_17
Flight distance : 62349 ft
Hi all,  Starting this forum post to collect user feedback on what improvements / issues the new firmware update have been found.
Please make sure all your batteries have been updated.
PS: Please keep this post on topic.
2017-8-21
Sparky_17
Here is the official release link: https://dl.djicdn.com/downloads/ ... utm_campaign=buffer
2017-8-21
fans7cac4655
Had trouble updating wirelessly but no problem using DJAssistant 2 on PC
2017-8-21
Anuvis
Flight distance : 1976736 ft
Greece
Nothing different for me i flew 3 battery's .I think that now i get in more sort distance image warnings....2.4 ghz NOT FIXED....
2017-8-21
hallmark007
Flight distance : 9827923 ft
No app update yet .
2017-8-21
Ques37
Flight distance : 27169 ft
No problem updating via app. Have not flown yet.
2017-8-21
Rawsome
Flight distance : 230827 ft
Is it just me or did the welcome beep changed a bit and seems a little more "melodic"
2017-8-21
S-e-ven
Flight distance : 5922034 ft
Thailand
Anuvis Posted at 2017-8-21 08:52
"2.4 ghz NOT FIXED...."
Mmmhh, I changed without using a OTG to 2,4 Ghz.
In 30 seconds, nothing to switch of or on, only let the RC wifi restart.
Or do you mean, that as soon as you change the batterie, it's back to 5,8 Ghz?
That is still happening, indeed!
2017-8-21
Anuvis
Greece
S-e-ven Posted at 2017-8-21 09:29
I have terrible lag in video in 2.4 GhZ so that makes that mode useless for me and yes every time i change battery it goes to 5.8.No otg. Europe CE Bug....
2017-8-21
TexasAerials
Flight distance : 566952 ft
went out to fly this morning, and was surprised by the notification that there was a new firmware update, so had to burn the first 15% of my first battery updating the firmware.   flew using 5.8ghz and OTG, i noticed that the 5.8ghz didn't do so well transmitting through some of the treetops, but other than that, everything seemed to work fine for me, same as before, but i didn't test any of the IFM.
2017-8-21
SteelTallon
Flight distance : 204094 ft
Updated using Wifi.  Update worked on first try to 2x batteries, Spark and RC.  Haven't flow it yet though.
2017-8-21
Mcbrich
Flight distance : 1412395 ft
Updated bird, remote and three batteries using Wifi.  Went smoothly and took about 20 minutes.
2017-8-21
HomePoint
Flight distance : 776007 ft
Everything updated easily via the DJI Go app.
Tried to switch to 2.4 on Nvidia Shield without using the OTG, but still 2.4 doesn't show up in wifi list.
2017-8-21
STech - Hathder
Flight distance : 459094 ft
Brazil
Update went very fine though WIFI.
Made a test flight indoor, everything was perfect! Need to test outdoor when possible.
One thing i notice: My spark is MUCH MORE COLDER AFTER FLIGHT THAN IT WAS BEFORE UPDATE, the top of spark are always warm (not hot to touch) before the update, and now its cold. (I am realy sure about this, i always put my hand to felt how warm it was after a flight or when are IDLE since i bought it.)
Anybody notice that too?
2017-8-21
Rawsome
Like wise, even after updating 4 batteries and flying one! Good point.
2017-8-21
DJI Thor
Flight distance : 13602 ft
HomePoint Posted at 2017-8-21 09:59
Could you please provide us a screenshot of this case? Thanks in advance.
2017-8-21
WilfredFireStee
Flight distance : 182215 ft
Argentina
Did a quick 2 battery flight test I'm still sadly getting video latency, if not more frequently. Also found that camera buttons were less responsive and had to press the on screen buttons after pressing video or camera buttons multiple times with no joy. Finally the stability when hovering at 2m ish was wobbly and moved more than previously in little to no wind. I made a video to show. I really didn't want to be moaning and again I'm happy the updates are here but im sure im not the only one facing these same issues but will do some further testing tonight. I've said the same on a few threads but if i get the chance this evening i will test the OTG function as it's not really worked for me previously (galaxyS8) and the dronie and helix but tbf i haven't had issues at all with those functions in the past.
Sorry for the gripes, believe me i really don't want to be here moaning i love the spark it's just been a bit problematic for me. Mainly the video latency problem. zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
2017-8-22
sparkguygc
Flight distance : 230141 ft
Update failing to 600... (with DJI Assist... 3 times now)
and the top of the Spark is untouchable its that hot!
2017-8-22
sparkguygc
sparkguygc Posted at 2017-8-22 01:14
Still hot but updating now... 99%!
2017-8-22
Sparky_17
Updated the AC, 3 batteries and RC without any issues last night.  The DJI GO 4 app finally became available to upgrade this morning; updated both iphone2 and ipad air this morning.  Will do a test flight later today.
2017-8-22
TexasAerials
TexasAerials Posted at 2017-8-21 09:43
update on this, it appears that the spark was still on CE standard low-power 5.8ghz.  not sure why it didn't realize and change the wifi settings after starting up back in the states.  turned it on just now and was notified by the app that the wifi would change as I am in a different region.  this will probably fix the issues i observed yesterday losing signal behind trees, and choppy video close-in.
2017-8-22
Spaners
Flight distance : 1542 ft
@homepoint
Is that when you are connecting to the spark or the remote ?
2017-8-22
Connor-UK
Flight distance : 202549 ft
STech - Hathder Posted at 2017-8-21 10:29
Yes noticed it cooler after update, flew it 3 batteries yesterday and was cooler than on 2 batteries day before
2017-8-22
Sparky_17
Connor-UK Posted at 2017-8-22 05:52
This is good to know that it runs much cooler.
2017-8-22
CarloRivera10
Mexico
I tested it with my 2 batteries, I had faults at 30 meters at 5.8ghz finding interference disconnected the aircraft and with the 2.4ghz channel just as saturated. Also came out unknown error with code 110 saying that could not take off and while taking off, it is worth mentioning that I have never crashed. Today I returned to actulizar the same version (V01.00.0600) and I think that already works well but permace the ineferencia flying in mode atti.
2017-10-19
