Major issue discovered.Not tight screw in motor
2274 24 2017-8-21
Anuvis
Flight distance : 1976736 ft
Greece
Today as i check propelers as a preflight check i realized that one prop was moving a litle when on the motor just a tick not too much so i tried another one with the same problem....Then i realize that one of the 2 screw down of the propeler witch screws the propeller clip ant the motor was not tight at all.....so i tight it put the prop and not the slightest move at all...
2017-8-21
Sparky_17
Flight distance : 62349 ft
Thanks for sharing this with us.  adding this to my preflight checklist.
2017-8-21
Anuvis
Greece
Sparky_17 Posted at 2017-8-21 05:55
Maybe this little detail is causing all these problems. Imagine a unit with more screws untight.That may cause mid flight off or other bad behaviors .
2017-8-21
STech - Hathder
Flight distance : 459094 ft
Brazil
Adding this to my preflight checklist, Thanks for share!
2017-8-21
LOKY
Flight distance : 22359 ft
Can you please, share the tool you use for the screws ?
2017-8-21
STech - Hathder
Brazil
Anuvis Posted at 2017-8-21 05:58
Its perfectly possible. I will check my screws now (and propellers feet).
2017-8-21
$gambino$
Flight distance : 1563980 ft
Looks like a 1.5 mm allen head
2017-8-21
Anuvis
Greece
I had never a crash or anything else hard land etc....I check the propellers and saw that one screw was not tight because prop when on was a slight tick moving ...Is it possible to un tight in flights or it came from factory...I dont know .I know for sure that the small almost not viewable vibration that the drone had in hovering is now gone ... Just imagine units that have more screws un tight they fly and during flight these screws un tight more ...this i am pretty sure can cause a mid-flight off
2017-8-21
S-e-ven
Flight distance : 5922034 ft
Thailand
LOKY Posted at 2017-8-21 06:01
I would say its Torx
https://en.wikipedia.org/wiki/Torx
2017-8-21
LOKY
Thanks! Looks like, size ? TX = ?
2017-8-21
lafoto
Flight distance : 1402680 ft
Portugal
OMG!... 4 screws not tied!...
#1
#1
#2
#2
2017-8-21
jyc
Flight distance : 2255846 ft
Thanks for the heads up.
2017-8-21
Anuvis
Greece
lafoto Posted at 2017-8-21 06:24
This is getting serious....
2017-8-21
STech - Hathder
Brazil
How a tied and not tied screw on Spark should look like? anybody take photos of untight screw? I dont want to over tight the screw and end loosing a motor.
2017-8-21
Anuvis
Greece
STech - Hathder Posted at 2017-8-21 06:33
I tight the screw with little force .Just with a little force until the screw driver stops in the lightest force.It is just in your hand you will understand.... BE CAREFOUL NOT OVER TIGHT IT MAY BREAK THE MOTOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2017-8-21
LOKY
TORX number ?
2017-8-21
lafoto
Portugal
I had 4 that with minor force did tight a bit more!...
2017-8-21
lafoto
Portugal
I had a kit from apple... i don't know the TORX number, sorry...
2017-8-21
Anuvis
Greece
This is the tool I use
2017-8-21
Anuvis
Greece
The tool i used is T6x40 you can see it in my photo up
2017-8-21
LOKY
Anuvis Posted at 2017-8-21 07:05
Thanks for the update !
2017-8-21
heliman
Denmark
Metal screws in metal must always have a little threadlocker (glue, i.e. lock-tite), at least in the rc helicopter hobby, where I come from.
Was’nt there any threadlocker?
Is it safe to remove the screws to have a look at them?
2017-8-21
Thor1
Flight distance : 196837 ft
heliman Posted at 2017-8-21 07:56
it would probably void your warranty and i wouldn't take them all the way off but just to loosen and look at them shouldn't hurt.
2017-8-21
Joe_CZ
Anuvis - thanks for this very practical info; I like your way of checking the AC before flying properly; I too found one screw slightly unloosen just when unpacking the new AC month ago;
What about to add information about the tool into your first post in this thread for anybody to see what tool they shall to use? Just an idea.
2018-8-4
Harry Moman
Flight distance : 311240 ft
Reminds me i better check all of mine since i have had them all apart from the drone ....
2018-8-7
