ImHereToCrash
Flight distance : 5381368 ft
fansa7dc5944 Posted at 2017-8-21 19:59
I don't think that the warmth of the battery is bad. The moderate rising of the temperature of every aircraft model. The one with video tramsmission get warmer than the one without. On the contrary, you should be worried if it would not getting warm. Because it is abnormal. Why? Because video encoding and transmitting requires cpu power to do so. Zenmuse X4s get heated after 4k video recording for a while. If Spark should getting colder it is consuming less power which means the video quality or range may be downgraded.
uhm? what? always better if its running more efficiently. if you are able to do exact same image processing with less overhead its always better. as an example, my Dell XPS 15 i had a intel driver update for the skylake iGPU which pretty much killed all thermal throttling i had when watching 4K in youtube.. which was a legit issue i had, my iGPU was throttling down to 650mhz after a few moments.. now it locks to 1.1Ghz on the iGPU and my fan either running much slower or does not turn on now under so loads i dont hear it and it runs 4K vp9 decoding no problem.
now i just hope Nvidia updates the 960M driver in my laptop, because once they kicks in the fan ramps up, still quiet but just loud enough to hear and is annoying if not playing music or something.
