MAVICDLNM
Flight distance : 10696686 ft
After 5 months of launch this video feed lag and frozen issues still exist in Epson BT300 when tried to use DJI Go 4 to control Mavic Pro. I am using the latest DJI go 4 4.1.4 in Moverio Marketplace.
I got this lag and freeze again last weekend when I tried to fly outdoor in a very sunny day. It happen in the first flight when Mavic and RC start then the video feed freeze or occasionally response. It take me 10mins to keep try and figure out to clear video feed buffer manually although I already click auto clear option, then everything get back to normal. I had this issue since purchase of Epson BT300 and post two times here to reflect the problem. But I guess no one really take it seriously after all. The above problem is still the old issue but only occur occassionally. Lucky such problem only happen when you connect BT300 to Mavic RC, so once you get into the DJI GO start there is either all smooth to go or the huge lag and video freeze you will encounter. So good thing is you won't have to worry about such issue happen in the middle of flight.
As said early if any owner of BT300 who want to experience such kind of lag or video freeze, you go ahead sample sync your flight log and try to start fly. You soon will know what I am talking about. The solution to this issue has been found and explained earlier, so I am not going to talk about it here. This time the problem is still relates to flight log, video and photo buffer. Once DJI go 4 get touch to this SD card control may get into problem with the app response, you can simply tried this by unplug the SD card from Mavic Pro and experience the video feed performance. I had talked to DJI technical staff in Hong Kong flagship store during a seminar, and he explain that is the hardware design issue of Epson BT300. Unless Epson fix this by firmware there nothing much DJI can do about it. But I can't found any channel reflect this problem to Epson, and get no choice to keep post the problem here.
