New Mavic Pro Firmware Released (22/08/2017)
1234567Next >
70447 274 2017-8-22
DJI Support
Flight distance : 2408 ft
Overview
  • All-in-One firmware version updated to v01.03.1000
  • DJI GO app iOS version updated to v4.1.7
  • DJI GO app Android version updated to v4.1.5
What’s New?
  • Fixed an occasional issue where DNG files couldn’t be opened.
  • Fixed an occasional issue where the camera would restart automatically during recording.
  • Fixed an occasional issue where the gimbal would drift after self-checking.
  • Limited the max descend speed to 2 m/s and max ascend speed to 3 m/s in Propeller Cage mode.
  • Improved image quality.
This firmware is also an update for DJI Goggles:
  • Added Head Tracking for Spark (with firmware v01.00.0600 or later), the Inspire 2 (with firmware v01.01.0200 or later) and the Phantom 4 (with aircraft firmware v2.0.0.16 or later and remote controller firmware 1.9.3).
  • Added remote controller signal strength icon.
  • Optimized audio quality.
Notes
  • Restart the aircraft and remote controller after upgrade is complete.
  • Please note that firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update to suit your preference.
  • If the firmware upgrade fails, restart aircraft, remote controller and DJI GO 4 or DJI Assistant 2, and retry.
2017-8-22
Asainz320
Flight distance : 1061594 ft
Wow nice! This fw update looks very promising. Updating now.
2017-8-22
fansa7dc5944
Flight distance : 50988 ft
Thailand
It is much better that you do not force updating as you did with Spark. I will wait awhile for all pioneers to report the results.
Thank you.
2017-8-22
PaulBirman
Flight distance : 374177 ft
Latvia
Does this update fixed problem with video recording quality, where you had to switch from NTSC to PAL and back for better image quality?
2017-8-22
fanseeba7327
Flight distance : 71329 ft
Tried to update. Came up with an error after what looked like it was almost complete. Tried a second time. Still didn't update. And now my battery has the two middle lights stuck on and will not power down the mavic. Plus the battery's status on the remote is Now also not showing battery power. Battery will not charge now. And I'm unable to reach try the firmware due to battery power to low message when trying to try update again
2017-8-22
DronePix
Flight distance : 765469 ft
Thanks, would be great if DJI elaborate how does this firmware "Improved image quality" for mavic pro.
2017-8-22
Kasiic
Flight distance : 56585 ft
Latvia
PaulBirman Posted at 2017-8-22 03:22
No, same blurry video   +1 sharpenning or ntsc/pal restart fix this problem
2017-8-22
DJ Enertia
Flight distance : 614065 ft
Im using a Galaxy s8+ and had major crashes with GO app 4.1.5 and my first flight I almost lost the Mavic so I finaly got things working with GO app 4.1.4 and updates to .900 which were not finishing it would freeze around 50% using my phone so I tried updating using the Assistant2 version 1.1.2_2 on my Pc but the drivers wouldn't load so every time I connected Mavic or controller to Pc using USB the Assistant2 wasn't recognising it,so I uninstalled Assistant2 and found older version Assistant2 1.0.7 which loaded the drivers correctly and I was able to update.
So im little hesitant to try the latest new update until since now all is working well no crashes yet im going to wait until more people post their testing in the field.
2017-8-22
calmari
Flight distance : 64944 ft
DJI please address this. Please let us save all current settings to our app with the option to name each settings file and then upload again.
"Please note that firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update to suit your preference."
2017-8-22
fansa7dc5944
Thailand
@DJ Enertia..... Then stay with the current firmware. According to release note there are not much benefit for you to update.
2017-8-22
calmari
DronePix Posted at 2017-8-22 03:56
Agreed               .
2017-8-22
DJ Enertia
fansa7dc5944 Posted at 2017-8-22 04:15
Yeah that's the idea for now...
2017-8-22
Asainz320
The update went fine from the phone (Galaxy S8+). Flew my first battery and everything looks ok. Will have to test image quality and DNGs now.
2017-8-22
Asainz320
A few unedited shots. Looks good to me.
2017-8-22
K4Unl
Flight distance : 122175 ft
fanseeba7327 Posted at 2017-8-22 03:32
Try updating again. If it reaches <50% you're screwed and have to send it in to get repaired.
Basically, it's waiting for an update now. Just put it in your Mavic and update. Keep trying till it succeeds.
2017-8-22
patman89
Flight distance : 288327 ft
K4Unl Posted at 2017-8-22 05:19
No you don't have to send your drone for repair.
This was a common issue with FW v01.03.0600. This can be fixed by contacting a moderator/admin and request an DJI Account reset. They enable your account to download a very old FW version which will fix this problem, then you can upgrade again via Assistant 2 without any problems.
A solution which worked for me as I was affected by this problem too:
- Remove DJI Assistant 2 from your PC and purge all remaining folders (don't forget local appdata)
- Install latest Version again and login with a different DJI-Account
- The drone should update as expected without any problems
- Re-Login your main DJI-Account and use it as before
2017-8-22
medicrx
Flight distance : 118455 ft
Can I just update the DJI GO app without updating the firmware?  I'm hoping the app update will fix the map & ipad mini 4 problem but I am hesitant to update the firmware until it is tried and true.
Or, is it an all or nothing update?  (App AND firmware)
2017-8-22
CuaC
Flight distance : 369626 ft
Any word on that "improved image quality"?
2017-8-22
patman89
medicrx Posted at 2017-8-22 05:42
You can update the app without updating the firmware! I am running FW v01.03.0700 and the latest app (4.1.5 Android) without any problems.
2017-8-22
Car147
Flight distance : 180351 ft
I was flying a couple of hours ago  and quite surprised that I did not get the update notification when I tested it all before flight at home. ( UK)
2017-8-22
yoyo3
Je vais faire beaucoup de fois. Bloqué, après avoir été bloqué à 11%, il semble tout à l'heure.
Donc c'est pour:
- mavic?
- batterie ?
- télécommande ?
-DJI GO ??????
Ou tout dans le même temps ?????
2017-8-22
rebelmark
Make sure you update the DJI GO app first.    My upgrade appears to be stalled at 55%.  I hope it completes.  What are my options if it hangs?  Just restart the drone and controller and see if it finishes?
2017-8-22
Jumbo333
Flight distance : 797930 ft
Hello yoyo3,
The update .1000 is for Mavic and Controller, both must be updated. If the battery need update, it's automatic.
For DJI GO 4 , it's an update different with Android or iOS and not directly linked to this update.
Happy to see French guys here !
La mise à jour .1000 est pour le Mavic et la télécommande, les deux doivent être mis à niveau au même firmware. Si la batterie à besoin de mise à jour, ce sera automatique.
La mise à jour DJI GO 4 est différente, c'est lié à Android ou iOS, et pas directement lié à cette mise à jour .1000.
Heureux de voir qu'il y a des français sur le forum DJI !
2017-8-22
rebelmark
It finally completed fine.  It took a while.
2017-8-22
Jffoto
Flight distance : 709 ft
Sweden
Updated without problems, but have not been up in the air yet.
Anyone tried out the new image quality yet? Any different?
2017-8-22
Bomberuk1
Flight distance : 16759 ft
got to laught at dji because there is nothing that they can improve on the mavic i think it is at its max potential where firware is concerned at
2017-8-22
Dutchgixxer
Flight distance : 738084 ft
I have just updated app mavic controller and 3 batteries. All went fine. I did charge all batteries to 75 % before updating Them. Go now for a test flight.
2017-8-22
Bomberuk1
cant edit or delete my post, WHY ?
2017-8-22
Nazar78
Flight distance : 5106037 ft
Singapore
The update using DJI Assistant 2 wasn't as smooth as previously updating to .0900.
With all my 3 batts fully charged, I successfully updated the RC to .1000. Then using first batt labeled #1, reached 32% I got the two middle leds, got stuck there for quite sometime and finally failed. Mavic now won't switch off. Tried few times and still no go. It scared the crap out of me!
Finally removed the USB connection then reconnect and the status showed new firmwares both .0900 and .1000. Tried again with the .1000 and it seems updating even with the two middle leds but very slow more than 10mins. Reached about 50ish % the lights went back to normal. Phewww!
Batts#2 and #3 has incompatible prompts as per-normal and it updated quite fast. Guys please ensure the batts are fully charged before upgrading the firmware! The first few attempts already drained the battery one led down. If < 50% we're screwed!
There was a NFZ database update prompt initially which doesn't got upgraded so I skipped. Now with the .1000 it still won't update. Downloaded 100% and the DJI Assistant 2 self-closed immediately when it starts transmitting at 0%. How do I update this?
UPDATED: The NFZ update on the DJI Assistant 2 doesn't work but it worked on the DJI Go 4.
2017-8-22
rebelmark
What do you mean upgrade the batteries?
2017-8-22
rebelmark
rebelmark Posted at 2017-8-22 08:25
never mind, figured it out.  You essentially just have to install each battery and it does a quick update on each once the main update is done.
2017-8-22
Nazar78
Singapore
If you have more than 1 battery, the others also needs firmware upgrades. You will see incompatible module prompt both in the software and app when you put in those other batteries. Just let it do the updating itself, best to upgrade all batteries at once.
2017-8-22
alex_markov
Flight distance : 39244380 ft
Bulgaria
I am afraid to try it yet ;) (My Mavic is doing very well lately with .0900). But have a question, how long I'll be able to postpone FW upgrade? Is there any chance to be enforced in the middle of the mountain on a beautiful scene with No option to fly before "upgrade"?
2017-8-22
Ex Machina
Flight distance : 1806362 ft
Bomberuk1 Posted at 2017-8-22 08:12
The more you post and reply the more forum features unlock.
2017-8-22
rebelmark
Just blew through a battery on a test flight, everything worked really well!!  Can't wait for my iPad Mini to come in because the iPhone is too small....
2017-8-22
Krevvy
Flight distance : 77493 ft
Mavic pro and 3 batteries all updated fine via iPad mini method.. not got the weather to fly tonight though!
2017-8-22
Mari
Flight distance : 1308780 ft
... just finished updating... did take very long after download to start with updating... Now RC, MP and all batteries are up-to-date again...
2017-8-22
Krevvy
Ok 1 bug I've found (or maybe just me being daft)
On iPad when I try to change the rth height or max height I get a numpad up and can change the value.. but there is no enter key or accept.. if I click off the keypad the alien isnt saved.
I plugged in my android phone to set these values and it was fine.
Is there supposed to be a done/enter key on the iPad keyboard in djigo?
2017-8-22
R_Adams
Flight distance : 9144 ft
fansa7dc5944 Posted at 2017-8-22 03:15
Thank you.
This is good advice if everything is working, you have nothing to gain from bug fixes that don't affect your current rig. I experienced issues on iPhone 10.3.3 and DJI Go 4.1.5.  Since I have been prevented from flying in the last update, I really have nothing to lose at this point. My specific issue was "Image Transmission Lost, RTH?" Since I am grounded, I'll spend the afternoon trying this on mine. Good luck everyone. Have a great day, Rick.
2017-8-22
ro_flyer
Flight distance : 7557283 ft
Brazil
Why all settings have to be reseted??? :-(
2017-8-22
1234567Next >
