Settings issue since update (v01.03.1000 / iOS 4.1.7)
1182 6 2017-8-23
Obicom
Flight distance : 731591 ft
I already updated my Mavic, RC, batteries and apps (Android 4.1.5 and iOS 4.1.7) the the newest FW version (v01.03.1000). Since that I am no longer able to set the YAW sensitive and Gain to my prefered values.  Under Android (v 7.1 on a Nvidia Shield) if I try to set the YAW sensitive to 0.15 the value is red and will be not accepted. The same with YAW Gain ... I want change to 50 but not possible. Under iOS I am able to set sensitivity to 0.15 but Gain max 80. Any idea why and how can I set my preferred values again?  Why iOS and Android behavior is not the same? To be honest I am a little bit confused ....
2017-8-23
DJI Thor
Flight distance : 13602 ft
As you can see on the app, the range for setting sensitivity for Yaw Endpoint is 50%~250%, please note the unit is %, so please check the figure that you input. Correspondingly, check others. And please note that you need to connect the drone firstly and then change the settings. Please let me know if I misunderstood.
2017-8-23
Obicom
Hi DJI Thor,
First of all thank you for your quick response. I think I found out where the issue is.
I tried to re-setup the setting for Rudder left/right under EXP. I deleted only the last two digits and changed from 25 to 15 and exit this setting.
After enter this point again to double check the setting the value was back to 0,25.
The problem is the separator "," ... for enter the value a "." is needed and will be changed to a "," from the software.
What does this mean? If I delete all digits and type in "0.15" instead of "0,15" it works but afterwards the value is shown as "0,15".
A little bit confusing but not a big deal (if known).
Best regards, Obi
2017-8-24
Mari
Flight distance : 1308780 ft
It has probably something to do that in Europe we use "," instead "." in other places on earth... for example €1,23 ( 1 euro and 23 cents) and $1.23 (1 dollar and 23 cents)...
2017-8-24
calmari
Flight distance : 64944 ft
Mari Posted at 2017-8-24 08:39
Just in case DJI take this a gospel and feel the need to make changes, the European UK uses "." Please don't change anything on our account
2017-8-24
Mari
Is UK still part of Europe
DJI should check settings of device and use that for input...
2017-8-24
DJI Thor
Obicom Posted at 2017-8-24 07:16
Hi DJI Thor,
Good to know that. Like Mari replied, it might be related to the area? But for me, I can not input the wrong number or mark onto the blank.
2017-8-24
