Decent 10" tablet mount & hood?
2111 10 2017-8-24
travelrikk
Flight distance : 21877946 ft
Malta
So I bought an iPad Air 2 specifically for use with my mavic pro. I bought a tablet mount + hood from ebay (generic, cheap one) but it turned out to be very flimsy and the hood doesn't even fit my iPad.
Are there any decent one that will fully support the iPad without feeling flimsy and able to add a sun hood?
Thanks
2017-8-24
lannes
Flight distance : 4465 ft
Thor mount
https://www.thorsdroneworld.com/
Mavmount
https://www.mavmount.com/
PGY TECH sun shades
https://www.pgy-tech.com/monitor-hood-for-mavic-phone
2017-8-24
Haskins
lannes Posted at 2017-8-24 00:50
Thor mount
Some mounts come an extension of the Lightning to USB to allow you to plug into bottom of controller. Do all the functions still work like follow me if using this cable?
2017-8-24
PHL
Flight distance : 1044062 ft
Happy with the PGY tech mount for my 10.5" Pro.
2017-8-24
travelrikk
Malta
Thor mount
Thanks for the help, might get a cheaper version of the first one
2017-8-24
chalde
Flight distance : 668314 ft
Much cheaper and works perfectly - bought a separate hood, but didn't get a chance to use it yet. Also got it on Amazon.
http://a.co/eybxzCb
That's the one I've been using (you can see it in the video below while testing my Galaxy Tab A 10.2)
2017-8-24
lannes
Haskins Posted at 2017-8-24 02:17
The usb ports on the bottom of both the mavic and the spark controller are below the section where the mount plates sit in both mounts.
In the lifthor which comes from underneath the controller to the tablet holder, there is a split section that should allow you access to the usb ports
https://static.wixstatic.com/med ... 2.jpg/v1/fill/w_498,h_332,al_c,q_90/file.jpg
The mavmount which I have, has full access to the bottom usb port
2017-8-24
Crafty Ralph
Easy enough to build one with some 1/4" aluminum and an iPad tripod mount.  Draw it out on the computer, print actual size, trim with scissors, test fit, cut out actual plate from abs, lexan, or aluminum.
2017-9-9
Crafty Ralph
Crafty Ralph Posted at 2017-9-9 14:28
2017-9-9
Lucas775
Flight distance : 50642090 ft
I use a mavmount.com and I am very pleased with it.
2017-9-9
Jyunte
Flight distance : 2103150 ft
Lucas775 Posted at 2017-9-9 17:16
Likewise! The MavMount is great.
2017-9-9
