GH4 Zenmuse shutter problem
3683 7 2014-9-18
quadslo
Slovenia
Shutter is not working properly on my GH4 Zenmuse. After the power up it doesn't work. But if I change some settings on the camera, it starts to work. But after another power up, there is the same problem.
2014-9-18
Blade_Strike
Flight distance : 872694 ft
They are aware of the issues and have a fw in testing
2014-9-18
craig.jump
Flight distance : 1738885 ft
Same here.. no shutter control on GH4..
Someone has said that its due to the AUX1 channel which is not used on the Gh4 gimbal being mid point...  (its used on BMPCC gimbal), if you map a channel to Aux1 and ensure the slider is at min,,, then shutter will work... (I have not tried this yet myself)
2014-9-19
Blade_Strike
Some units are having this issue. I can say my shutter works fine. They are aware of this issues and working on a fix.
2014-9-19
magnus.hammarst
Sweden
I also have the shutter control problem. Is it possible to test the GCU 1.6 beta firmware?
2014-9-19
magnus.hammarst
Sweden
I can now confirm that my shutter works when I assign a channel to AUX1 and set that in off position.
2014-9-20
quadslo
Slovenia
I also tried your option and now mine works! Thanks
2014-9-21
DJI-Terry
China
Guys, new firmware will fix this. It's coming shortly. Thanks.
2014-9-22
