droneflyers.com
Flight distance : 60709 ft
Less latency is unlikely to happen - wifi is not designed for real-time FPV. It is designed, in the case of all Phantoms, to allow you to frame your shots and videos.
Plenty of extra payload capacity on an FC40 to put a small FPV camera either in addition to - or instead of - the stock cam. An analog cam will probably provide the least latency since I assume some is lost in processing to composite). Of course you need an FPV screen then too.... |
