FillFeile
Hello Together,
I'm working on a project with the NAZA M LITE controller combined with a Raspberry Pi. The aim of the whole project is to build an autonomous quadrocopter that is controlled by the Raspberry Pi. To achieve this we have connected the A, E, R, T... Channels of the NAZA M LITE controller to some of the GPIO Pins on the Pi. The GPIO Pins simply simulate a connected RC-Receiver: they just put out a standard pulse width modulation. The whole signal is configured to 20 ms and the high signal varies from 1ms to 2ms.
Now my problem:
If I put on a 1ms pulse on for example the A channel all is good. Trough the NAZA Software I can see that the A channel drops to -1000. If I afterwards put a 1ms pulse on the E channel the same result (drop to -1000) appears for round about 1 sec. After this short time the A and E channel are jumping to the middle of their signal range (green or in numbers 0). In this state I am not able to reach any negative values on both channels. Only a restart of the NAZA controller resets this state.
I really can't imagine why this is happening. Any ideas?
