ennobrett
Hi Guys,
noobie here and spent many hours trawling through this forum for lots of tips and tricks. Thought I would share a checklist I put together yesterday for the Inspire. Let me know your thoughts, anything to add or remove? I have attached in word format too. I have it printed and laminated so I can check off with a whiteboard marker before every flight.
Hoping for my Inspire to arrive later this week... Not sure I want to take it out until the new firmware is released. The list will change as I get more experience and able to refine it. I don't really have any idea as yet, just regurgitating what I have gathered from lots of reading so your input is greatly appreciated.
Pre-Flight Check List
Visual inspection for defects
Batteries fully charged and checked - Transmitter, UAS, iPad, iPhone
Props tightened and locked
SD card in camera
Lens cap removed
ND Filter needed Yes / No
iPad monitor brightness set to high and hood installed
Antennae up and parallel
Transmitter turned on (press once, release, then press and hold for 3 seconds)
Ensure Transmitter is in P Mode
UAS turned on (press once, release, then press and hold for 3 seconds)
Flick the transformation switch on transmitter up and down 4 times quickly to convert from travel mode to flight mode or use the app
DJI Pilot app quit and restarted, no other running apps on iPad
Start Shou screen recorder app on iPad and start recording
Tap bar at top of app (Safe to Fly GPS) for full status
Maps are cached (move the map around, zoom in an out)
Compass calibration (orange rotate 360 deg on flat, camera facing away from you, turn green nose down, camera near nuts) Light will go off and change to blinking purple or red?
IMU check / recalibration
Minimum return height adjusted (check for tallest object and set accordingly)
Clear frequency selected
Beginner Mode selected
UAS placed in safe launch and recover position
Purple flashing light = GPS lock and safe to fly
Home point reprogrammed via app
Video recording started
Area clear of people / obstructions
Do not use auto take-off or auto land – BUGS!
Take Off
Flight Check List
Hover close for 20 seconds. Look / Listen for defects
Confirm expected stick operation
Raise landing gear
Monitor battery power
Monitor signal strength
Keep line-of-sight with UAS if possible
Return to home at 30% battery
Landing gear down
FLY SAFE, FLY SMART. DON’T TAKE RISKS!!!!!!!!
