Lightbridge only giving me 8 channels with 14SG, what I'm doing wrong?
4330 8 2014-10-21
Andycorleone
Hi I tried everything but still end with the same issue, Lightbridge only giving me 8 channels per radio in this case the futaba 14SG
what I'm doing wrong? if I connect two radios and I can get 16 channels 8 per Remote. but can't find a way to add more than 8 channels to a single Transmitter. please any help is apreciatted
2014-10-21
DJI-Tenna
China
You need to change the CH Mode to 12 or 16 channels.
you can do it by following steps:
1. Select System on the controller
2. select Trainer
3. Scroll all the way until you find CH Mode on the bottom of  the list.
2014-10-21
archer02
Any clue now with the new firmware and 8 channels I have very low signal strength and range and video now is half of what it was before new upgrade? I now have video loss as well as half the range as before??
2015-5-25
Linolens
Flight distance : 501250 ft
Macao
archer02 Posted at 2015-5-26 10:02
Any clue now with the new firmware and 8 channels I have very low signal strength and range and vide ...
same as the I1.
Downgraded.
2015-6-9
svoyakd
Ukraine
Hello. Have same problem. Change 8CH to 16CH in TRAINER, but with this setting any channel not work. It work only when set 8CH
2016-9-3
brich12003.yaho
Not sue if you meant you were using to receivers in Dual mode ?The 14SG comes with a single 8 channel receiver if you want to get 14 channels to work on your transmitter you will have to purchase a second receiver and use dual mode in your TX .Click on link below
2016-9-6
brich12003.yaho
This may be a better link ...hope this helps
2016-9-6
svoyakd
Ukraine
With Lightbridge futaba reciever not used. Futaba connect to LB ground unit through trainer port.
2016-9-6
C.G.
Austria
DJI-Tenna Posted at 2014-10-21 21:43
Nice Info... thx a lot  !!
Grettings from Austria
2017-3-12
