Stronger and Stronger! Upgraded Pavtube H.265 Video Converter Review
2391 2 2015-4-15
Sindymaya
With the newest codec H.265/HEVC coming out for a long time, have you ever enjoy the nice H.265 movies on your handle devices or media players? Is that cool?
What’s new?
Fix the bug of breakdown when importing MXF and XAVC format.
H.264 Baseline/Main/High, three standards are all supported well.
H.265/HEVC decode/encode well.
Key features:
Convert various video/audios as input and output.
So many popular editing tools and media players are available.
Easy operation workflow and faster conversion speed.
Extra acceleration function for Windows users.
Strong ability of setting and editing output vides.
Download address:
Official download:
Amazon download:
Cnet download:
2015-4-15
ohmygeeks
Taiwan
How to Convert H.264 to H.265 Video
WonderFox HD Video Converter Factory Pro is so far the most professional product that supports H.265 stable and safe conversion in the software market. You just need to set the output format as “H.265 Video”. The following sections present detailed steps about how to convert H.264 to H.265 video.
1. Add one or more H.264 video files you want to convert to H.265 video;
2. Choose the output format as “H265 Video”;
3. Run the conversion;
4. Open the default output folder to check the H.265 video files.
Note: You can use the HD H.265 converter to download H.264 or H.265 video from video websites, through the “Download Video” function.
2015-10-21
areudit
Singapore
You may prefer to this guide: http://www.faasoft.com/articles/h265-converter.html
High Efficiency Video Coding (HEVC), also known as H.265, is a video compression standard, one of several potential successors to the widely used AVC (H.264 or MPEG-4 Part 10). When compared to H.264/AVC, HEVC has about two times compression ratio while retain the same video quality, which means HEVC has much better video quality than H.264 at the same bit rate. HEVC/H.265 is widly used in 4K videos and Ultra High Definition Television (UHDTV). It even supports 8K UHD (4320p, 8192x4320).
To get smaller video size yet improve quality using the same bitrate, more and more people convert H.264 or other HD video to HEVC/H.265.
It also lets you convert H.254 video to H.265 video.
2016-6-14
