Cacc
It will have to be modified to fit. The quad itself will fit without problem, but the landing gear cutout needs to be modified. The landing gear on the Phantom 3 are longer and more spread out. To make a Phantom 2 case work you will need to cut the foam a little deeper and shave off some foam on the sides. The props are the same size and the batteries are just a hair smaller, so they will still fit in the battery holes of the Phantom 2 case even if just a touch loose. |
