kelly
I can't stand the RTH landings, so like most, I hit cancel once it's where I want it. Yesterday, it didn't "cancel" and smashed the ground in its usual fashion, causing it to flip over and throttle up! It took way longer to shut down as well all the while kicking up gravel. I cleaned it up, did a quicky test flight, and all was well UNTIL I shut the radios down. It wouldn't restart, the gimbal moved about 20 degrees and stopped, and all else failed. I went to eat supper to let it AND me cool down and still no luck. Remembering the typical IMU reset techniques, I did a drop from a few inches upright on the landing gear (opposite of the way it hit) and sure enough, I could now make contact and perform all the IMU calibrations as a couple of numbers were off and it required a reset to even run. Thanks, but NO THANKS! |
