mark.rompies
Flight distance : 55594 ft
Indonesia
Howdy!
Since I use my motorcycle as a major transportation vehicle, I setup my Shad SH39 topcase to be able to carry my P3. For the bottom, I put plasticine modelling clay to make the bottom of the topcase level, on top of that I put two layer of hard surface plastic with one layer of plastic bubble in between. Wrap them with a plastic wrap for food, so I can remove (keep it, and ready for use in the future) this base whenever I need so I can still use the topcase for other use without worry to make the bottom of the box oily because of the plasticine clay. I use the condensed paper foam from P3's original box, cut it to match the dimension of the topcase, and fill the leftover space with unused newspaper. This setting is pretty safe so far. If one of you could notice some unsafe point(s) would you please let me know? Thanks!
Here's some pics:
1. The empty box:
2. With P3 inside:
3. The topcase then can be easily closed:
4. Easily attach to my motorcycle, ready to ride:
Thanks for viewing!
Rgds,
Mark
