Dji Phantom 3 pro - Problem with Jiggling
2518 10 2015-5-14
danthun
Flight distance : 14639 ft
Sweden
Dji Phantom 3 pro - Problem with Jiggling. Has flown about 5 times and not had any problems. and suddenly when would fly so right from the start as shaking sideways. I try to change the propeller but it is equal. I have calibrated imu and Gimbel.Watch the video and you will see.
What should I do?
2015-5-14
Fulgerite
Did you calibrate the compass before flight?
Otherwise it looks like a hardware problem.
2015-5-14
danthun
Sweden
Fulgerite Posted at 2015-5-15 02:46
yes absolutely, several times and it becomes the same.
2015-5-14
PaulOTron
Remove the white foam piece from behind the gimbal maybe?  It's packing material.
2015-5-14
danthun
Sweden
PaulOTron Posted at 2015-5-15 02:51
It is removed.
2015-5-14
fineartstudio
Portugal
Hi!
I need help please.
Description of problem:
Problem with Jiggling. I was testing the drone for the first time then this error occurred ,  drone start shaking sideways.
I removed the foam piece from behind the gimbal and calibrated the drone, but remains the same.
Watch the video and you will see the problem.
2015-5-19
Daninho
Flight distance : 70203 ft
Two different Problems i guess, the first video must be a gimbal problem, Maybe something went in the gimbal motor or something is blocking it etc.. it looks like a defective unit. The 2nd video is just the rolling shutter effect cause of vibrations. Some P3s have it, some not that much . Rolling shutter will appear on sunny days combined with wind the most. The Phantom1,2 and 3 can hardly compensate the vibrations to the gimbal because of the small size and stiff materials used. Normally you have to balance the motors, balance the Props or try different props (which is not possible sadly), and buy ND Filter.
2015-5-19
fineartstudio
Portugal
Daninho Posted at 2015-5-19 22:37
Two different Problems i guess, the first video must be a gimbal problem, Maybe something went in th ...
Thanks for the reply and for the help.
2015-5-19
pmarkus
fineartstudio Posted at 2015-5-19 22:09
Hi!
I need help please.
Have you yet done compass and imu calibration and updated fw ?
2015-5-20
Kawaman1
I had a similar problem with the gimbal twitching - I upgraded to firmware 1.1.6 and it was cured
2015-5-20
fineartstudio
Portugal
My version is 1.1.8 and same problem....
2015-5-20
