workoner
Flight distance : 15046 ft
Ukraine
Dont know how it on latest FW, but i have this problem right from box and on FW from 2015.5.6 Symptoms are:
1. Right after power on - all works fine
2. Few minutes on ground or in the air - and slave TX lost its signal. I still can operate camera, but have no picture or any status info from Inspire 1. Button, that return camera to its original position (yaw) stop working
3. Nether restart app or any use any other devices, or custom frequencies didnt work
4. Work only power cycle remote, but not for long.
After some close look i noticed that slave TX has abnormal heating form bottom side, right at HDMI port. its about 10-15 deg celsius more, than on master TX. Try different condition - with ipad\iphone plugged in and without - same result.
Isuggets - there is some sort of problem with overheating internal components. 5 min result int 50-55 deg celsius on plastic surfaces! This problem may cause a lot of flyaway, if its happen on master TX. So best way - test all on ground
TX was sent to local dealer few day ago. Waiting for result |
