Expect 15-20 minutes of flight time. You don't want to run your battery too far down. It hurts the battery - and you risk getting into trouble - it might want to do a Return To Home and might start flying by itself, which can be quite the shock. I don't go below 25%, (20% max).
Flying style has an impact too. Flying fast - and going up high will naturally drain battery a bit faster. If it is windy it will also use more battery - because it corrects itself and fights the wind constantly.
In fact, I would not be surprised if recording 4K video during all of your flight will also use up some extra battery power. So not capturing video might also give you a bit more flying time (kindda defeats the purpose, but I'm just trying to think about how we could get the longest flight time).
And as others mentioned - flying with Prop-Guards is extra weight and wind-resistance and will likely take a few minutes of flying time. Sounds like you were right flying with them on considering your crash. But in general I'd fly without them - just don't crash ;) I don't want to make anyone afraid of prop guards - but there were stories with the P2s about Vortex Ring Syndrome especially happening to people descending quickly (straight down) and it seemed to happen more often to people using Prop guards. They did slow down the descend speed to 2m/s (3m/s for the P3) so it is likely not a huge problem anymore.
Buy your DJI-gear, batteries, cases by using this link - it'll help me out
