Monitor mount for Ronin-M
17803 27 2015-5-20
anders_montgome
Norway
Since dji have not released a monitor mount for the ronin-m. What kind of mount for accesories are you recommending to use with the Dji Ronin-M? I´m still trying to find one, and mine will arrive in the post today.
2015-5-20
DJI-Cathy
it is coming soon
2015-5-20
noipego
Greece
well DJI has a different perspective of the 'soon'word...we still trying to find ppl/friends/passengers who own ios devices to get ronin-m to work....
i'd suggest for mount something like this http://www.amazon.de/Manfrotto-3 ... to+386BC+Nano+Clamp
its cheaper than originals DJI and small enough...u can find cheaper if you look for 'bicycle clamp mounts'
2015-5-21
anders_montgome
Norway
Thanks noipego, Luckily i got an iPhone so i got mine to work as i wanted to.
2015-5-22
noipego
Greece
anders_montgome Posted at 2015-5-22 16:24
Lucky you !!
for mount check this out too http://www.droneland.nl/en/drone ... tion-arm-small.html
they also have ultra thin paralinx hdmi cables...they ship from Holland
2015-5-22
anders_montgome
Norway
noipego Posted at 2015-5-22 21:01
Lucky you !!
for mount check this out too http://www.droneland.nl/en/droneland-mini-camera-fric ...
Thanks, i think ill go with the other mount, the shipping to norway was 50 euros for this mount. I got some thin hdmi cables from pearstone that works fine.
2015-5-22
gabereuben
I just bought an Impact clamp much like the one above, with a Pearstone strongarm. It holds the SmallHD 502 really nicely. I have an issue with powering the SmallHD 502, however. I am currently using an LP-E6 to D-Tap coiled power cable, the one here:
http://www.bhphotovideo.com/c/pr ... to_D_Tap_Power.html
It plugs into the D-Tap on the bottom of the Ronin-M camera mount, and as a result, pulls on the gimbal itself. This makes the motion way less smooth, and really works the motors a lot harder. Anyone have any thoughts? I think the easy fix is to charge the 502 with LP-E6 batteries, but I don't own any and don't necessarily want to buy any if I don't have to.
2015-5-22
AndersMontgomer
Norway
gabereuben@gmai Posted at 2015-5-23 05:26
I just bought an Impact clamp much like the one above, with a Pearstone strongarm. It holds the Smal ...
I would get some lp-e6 batteries, if you get the off brand they are pretty cheap. I got some wasabi power np-fw50 for my a7s and they work like fine. i guess that their LP-E6 batterie would work just Ok and you could get more than two of them. I got 5 LP-E6 for my Ikan vk7i monitor and they last about an hour each.
But I just have to tell you that i envy you on the 502, must be a great monitor. But my next purchase will probably be the litepanel caliber light kit or the shogun.
Another downside of using the D-tap on the ronin is that it does not last as long, since you use the ronin battery, to power the monitor. I got a D-tap for my monitor and i will try it, but it will never be my main power source. So it´s probably good to have the D-tap connection with you incase you run out of batteries, but I would not depend on it as a main power supply for the monitor.
2015-5-23
Alexauwa
Is the top rod of the ronin-m a standard 15 mm rod?
2015-5-23
AndersMontgomer
Norway
Alexauwa Posted at 2015-5-24 01:46
No, i think the diameter is 25mm
2015-5-23
Alexauwa
AndersMontgomer Posted at 2015-5-24 03:50
Thank you
2015-5-23
info.richardhar
Flight distance : 357162 ft
The DJI Ronin Monitor Mounting Bracket A works on the Ronin M with the DJI Ronin-M (Mini) Handlebar Shim from CineMilled.
2015-5-23
AndersMontgomer
Norway
info.richardhar Posted at 2015-5-24 09:45
The DJI Ronin Monitor Mounting Bracket A works on the Ronin M with the DJI Ronin-M (Mini) Handlebar  ...
I know it works just fine if you use the cinemilled handlebar shim, but I did not want to spend 200 usd on a monitor mount.
2015-5-24
mark
I bought a ePhoto tripod clamp for $11, works great.
2015-5-24
AndersMontgomer
Norway
I have ordered the Manfrotto Nano Clamp 386BC, supposed to work fine. cost a bit more but can hold 4 kg.
2015-5-24
erikhill
These two options will work since the rod is 25mm. One with a ball head for 75 and one without for 50. I personally think the ball head version would be more useful so you can angle your monitor exactly where you want/need it.
http://www.bhphotovideo.com/c/pr ... _monitor_mount.html
http://www.bhphotovideo.com/c/pr ... y_carbon_fiber.html
2015-6-3
Tuukka
Finland
Hey Anders, did the Nano Clamp work for you?
Is it big enough to clamp it on the top handle?
2015-6-3
DJI support 8
http://store.dji.com/product/ronin-m-monitor-accessory-mount 2015.jpg
2015-6-4
AndersMontgomer
Norway
Tuukka Posted at 2015-6-4 08:36
Yes the manfrotto nano clamp worked perfectly for me.
2015-6-4
Tuukka
Finland
Thanks Anders!
Mine arrived yesterday, just perfect! Great tool for many things.
2015-6-6
sveilien
My solution
2015-6-6
mark.vesinet
What app is that?
2015-6-13
sveilien
DSLR Controller, for Canon only.
2015-6-13
TheRealCookie
Costa Rica
(For your german audience)
Whats about this?
http://www.amazon.de/Verstellbar ... rds=gopro+halterung
2015-7-1
finnschi
Manfrotto Nano Clamp  is cheap and works perfectly!
2015-7-2
boey
http://www.amazon.com/gp/product ... &smid=ATVPDKIKX0DER
Found this to be a quick solution to mount a monitor on the cheap and it works flawlessly so far
2015-8-31
PJM
Flight distance : 1962 ft
Question for you. Do you have issues with interference and with the connection?  I have a similar set up but when i turn on the ronin it kills the dslr controller app. Not sure why!
thx
-p
2015-9-2
listern
Belize
What tablet holder are you using? I have been searching the net and can't find one like that.
2016-8-15
