Remote Controller Doesnt Work on Ronin-M
9071 13 2015-5-21 17:54:54
angus
Beginner
Anyone else having problems with getting their remote controller to work on the Ronin-M?
I'm following the manual exactly. I turn on the Ronin M, press the bind button, it doesnt flash green, it goes green automatically. Then I turn the remote controller on, its fully charged, has the green power LED and 3 out of 4 small green LED's lit. Nothing happens. Think mine is faulty?
2015-5-21 17:54:54
anders_montgome
Beginner
Norway
I did not have a problem with mine, it just connected when I turned the Ronin-M on. Try to reset all settings in the app, and turn on your ronin first, let it set for a few seconds, and then turn on the remote. When the ronin is turned on and the remote is not connected there is a red light that blinks, but it turns green when you turn on the remote.
Hope it will work for you.
2015-5-22 00:28:20
angus
Beginner
My mistake!
on DJI Assistant under "More" there is a setting called Internal Receiver off, the icon is a bit misleading as to whether it is on or off, I thought I had tested this setting before with no success but I just tried it again then and it fixed it! awesome!
2015-5-22 02:19:09
curtisjamesphot
Beginner
Mine won't connect. tried the setting receiver off and reset defaults. Anyone know how to bind the two?
2015-5-25 17:56:24
DJI-Cathy
Intern Pilot
curtisjamesphot Posted at 2015-5-26 09:56
Mine won't connect. tried the setting receiver off and reset defaults. Anyone know how to bind the t ...
Turn off your remote before you press the Bind hole, which is different than Ronin
2015-5-25 18:06:47
veronik
Beginner
DJI-Cathy Posted at 2015-5-26 04:06
Hi! I have the same problem. The remote control doesn't work.  It just worked one time: The first time I activated the ronin  (so this makes me think it's not a problem with the controller itself!) . But I didn't use the DJI app yet.  After activating the app for my samsung a week later, It didnt work anymore.
I followed all these advices : turn off the controller, press the hole button, set the app internal receiver on , the bind light i green, turn on the control, which lit green and is charged, but It doesn't work!
Someone could please help me?
2016-5-12 03:10:13
kazakov-sasha
Beginner
Russian Federation
The same trouble, anyone help me
2016-8-13 08:18:44
fansc0824fd0
Belgium
veronik Posted at 2016-5-12 03:10
Hello Veronik,
Do you find a solution?
I have the same problem, The tumbr is not green only the Ronin...
Tank U !
2017-2-1 11:59:01
fansf8c75314
Beginner
Turkey
Merhaba;
Ronin MX kumandayı update ettim ve kumanda şu anda hiçbir şekilde açılmıyor. Işıkta yanmıyor. Kumandanın içini açıp reset ettim ama değişen bir şey yok. Bilgisayara bağladığım da USB aygıt tanınmadı hatası veriyor. Çözümü bilen varmı? Ne yapabilirim.
2017-5-1 13:28:29
fansf8c75314
Beginner
Turkey
hello;
i updated to remote controller. But it in not working. No ligth in command. I resetted and conneted to PC but USB not working that. What can i do?
2017-5-1 13:31:26
carlosbravo
Beginner
Colombia
I have the same problem, I update the control and It doesn't work its Dead
2017-5-22 14:34:39
fansfc1349dc
Beginner
Hungary
Hello
Can anyone help me? I'm trying to set up my ronin-mx since two days and it's motors won't work. I followed the instructions in the manual, but nothing happened, it's just swinging on the tunning stand. I tried to turn on/off Briefcase Mode, Internal Reciever, Camera Base Invert and Roll Control, tried to restore default settings too but only that little light turned green from red, or inversely, I hope Ronin-MX can do more...
2017-6-30 10:28:05
djiuser_qdYiP2k
Same problem here with my ronin mx. Do DJI have any assistance ?
Thanks in advance
Marcus
2017-8-11 10:51:28
Wajeb
Beginner
Saudi Arabia
I can't even get my LED lights on the Ronin M itself to blink... I remember along time ago they used to blink... now the ronin m works, remote turns green but nothing.
No red blinking or green blinking
2017-8-12 05:22:20
Close
DJI RecommendsPrevious /1 Next
